Old 07-22-2011, 01:06 AM   #1
sturner
sturner is on a distinguished road
Default Need help with vacuum
Can anyone tell me where the two red arrows go to. I dont have a vacuum fitting on the passenger side of my motor and I dont see a vacuum fitting on the power steering reservoir. Oh and where does the purge line from the charcoal canister go to? After these questions have been answered I'll be done. Thanks in advance.
sturner is offline   Reply With Quote
Old 07-22-2011, 12:07 PM   #2
mirage83
That vacuum valve is on the power steering pump, not the reservoir.
The other is a metal bracket with the vacuum tube on it mounted near the front driver side of the engine. There's actually a lot of vacuum lines running around over there, so it can be missed if you aren't looking in exactly the right area.
I'll have to take a look at my bay to see where the charcoal lines run.
Old 07-22-2011, 07:58 PM   #3
sturner
thanks. I figured out one of them runs to the vacuum fitting on the air box. I've attached another picture, can someone tell me where that line goes to. I dont see any more open fittings on the driver side block. Thanks again.
Old 07-22-2011, 09:32 PM   #4
87supra7mgte
Purge line from charcoal canister goes to the BVSV on the thermostat housing, should have 2 fittings on it and from the top of it to the left side of your throttle body when looking at it from the drivers fended. This is to keep your combustion temp down after warm up.
Old 07-22-2011, 10:07 PM   #5
mirage83
Can you post a pic of the line you're talking about on or near the TB? Can't tell for sure which line you mean from that diagram.
Old 07-22-2011, 10:08 PM   #6
sturner
thanks. any clue on the second picture?
Old 07-23-2011, 04:11 AM   #7
sturner
OK last question I hope. Where does the line from the image run to? For some reason the people who installed the last motor in the car before I got have a line running to a vacuum T and then short line on one side and a really long one on the other. Hopefully after this I'm done. Thanks!
Old 07-23-2011, 04:46 AM   #8
MJG
MJG's Avatar
Looking at your picture, I will suggest this is the PCV (positive crankcase ventilation) line, which runs across the cam covers and on to the turbo intake.
Old 07-23-2011, 05:28 AM   #9
sturner
I have 7MGE and I'm stumped about this. I have connected everything else and the diagrams and haynes manual say nothing about it.
Old 07-27-2011, 10:10 PM   #10
sturner
anyone have an idea?
vacuum line diagram/pix? 7mgte 87supra7mgte MKIII Supra 0 06-14-2011 03:56 AM
JDM vacuum lines. please help! Suprasexy MKIII Supra 2 01-04-2011 01:34 PM
really could use help - vacuum, race on the 26th carl johansson MKIII Supra 2 12-24-2007 11:37 PM
Newbee: Question About Vacuum lines.. Alejo_NIN MKIII Supra 3 01-12-2006 07:18 AM
vacuum advance/retard tonster MKII Supra 0 09-16-2005 06:43 PM
