Old 07-30-2011, 03:45 PM   #11
Meekmeek
Meekmeek is on a distinguished road
I'm getting oil in my intercooling pipe.
Mk3 7M newbie.
Meekmeek is offline   Reply With Quote
Old 07-30-2011, 03:56 PM   #12
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
The way the ct26 is put together, the bearings and seals, even when brand new, tend to leak oil into the intercooler piping, eventually letting the oil rest in the intercooler. Use gasoline and clean it all out. rince the piping and intercooler off afterwards and reattach to the car. Good luck.
Carlos
Ps. I almost painted my intake manifold black... Now that i see the end result, im happy i did'nt!!!
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
Old 07-30-2011, 04:02 PM   #13
Meekmeek
Thanks. Will do? How do I tell if I have a CT26? It says a/r .70.
Mk3 7M newbie.
Old 07-30-2011, 05:33 PM   #14
El Supracabras
El Supracabras's Avatar
That's no ct26.
Checking codes is in the faq section.
Breathers would be better than nothing but a nice functional catch can setup would be ideal.
Oil leaking from that line on top of your turbo will burn off quickly so it may not look like it's leaking. Make sure that fitting is tight. While you're at it make sure ALL the fittings and hoses are tight.
A leaking intercoler pipe will cause the car to run like crap, fix it.
Oil in the intercooler is not uncommon but excessive oil in the intercooler might mean the turbo is about to check out.
Keep at it, it gets worse before it gets better but after some time, research and money it will get better.
Old 08-02-2011, 01:57 AM   #15
Meekmeek
I'm hoping to find a write up on the oil pump. If anyone knows of any I would greatly appreciate it. Also, we discovered an oil leak around the pump area. Do you think that could be it?
Mk3 7M newbie.
Old 08-02-2011, 11:31 AM   #16
man I see mods and relocates galore.. Your best bet is to park it. strip it and put it back together piece by piece, going over it with a fine tooth comb, fixing, cleaning and sorting inch by inch. looks like some ebay parts made their way into your engine bay. While there's nothing wrong with that, looks as tho he got in a hurry and didn't really care what it looked like in there.
oh a word of advice, before you go unhooking wires...mark them, for the love of god. put tape on the wires and write it down on a piece of paper or something so you know were that guy had them.
Old 08-02-2011, 12:09 PM   #17
El Supracabras
You still haven't posted the actual oil pressure you are getting. I would highly recommend sorting out the wiring and vacuum line disaster and performing a few basic engine health tests before doing anything drastic. As Green said, it looks like someone was in a hurry and just didn't care about the outcome. It may be well worth it to take some time, learn what everything is and start cleaning it up. Start on one side of the engine and work your way around.
Check you're actual oil pressure before tearing into the engine.
http://www.cygnusx1.net/Supra/Librar...Section=LU&P=4
Old 08-02-2011, 09:30 PM   #18
MJG
MJG's Avatar
Looking at your pictures and reading that an IC pipe boot came off, you have numerous entry points for dirt, into your engine.
You may very well have a dusted engine which will account for the loss of engine oil pressure.
A turbo in good condition will not leak oil past the seals. The stock PCV system for the 7MGTE, routes the vented gas into the intake, which carries oil vapor and will coat the IC and pipes with oil.
Since your PCV plumbing has been removed, oil currently is not being dumped into your IC by the PCV.
Your turdo seals could be shot and allowing engine oil into the compressor section of the turbo and being pushed into the IC system.
Old 08-04-2011, 03:09 AM   #19
El Supracabras
This could also explain a drop in oil pressure.
Old 08-04-2011, 04:30 PM   #20
Meekmeek
Thank you. I started my tear down. I'm cleaning thing up a bit and trying to see what I see that needs work. I ordered my oil pump but it won't be here till Wednesday. I'm checking all lines and seals. There is an oil leak. But I can't tell where its coming from. It literally sprayed my radiator when I had the car running yesterday. I was trying to see if there were any other things I could notice. I went and got some purple power so that I can clean it up a bit and it'll be easier for me to find. Anything else I should check while im at it?
Mk3 7M newbie.
can i learn to drift using mkiv auto? seantanct Non-Generation Specific Questions 5 01-08-2009 09:58 PM
Want to learn about the Mkiv Supra? pwpanas MKIV FAQ 6 09-06-2008 05:37 PM
newb here wants to learn alot :) hitm4n666 Non-Generation Specific Questions 8 08-19-2007 04:50 AM
Who wants to learn... Stoverus Off Topic Forum 6 10-21-2006 06:30 PM
NOOB, but wants to learn. drifterkid240 Non-Generation Specific Questions 4 09-10-2006 07:53 PM
