Old 09-27-2005, 07:49 AM   #1
kewlcoconut
Default TPS or Knock Sensor??
My supra has been acting up lately. It is idling pretty weird. If I drive it for about 10 minutes or more and then turn it off, and start it up again about 20-30 mins later, the RPM goes up and down like the car is breathing really heavy. The RPM needle just goes up and down really heavily and the car sounds like it is going to stall. Once in a while it will fluctuate so close to 0 RPM that it will just stall. My engine light is on, and it says my knock sensor and TPS have errors. I took it to my mechanic, and he checked it out, and he said it was the knock sensor. But I want to make sure thats the case.
Any help/suggestions??
Old 09-27-2005, 09:33 AM   #2
knock sensors generally don't cause erratic idle... they just throw a check engine light and retard the timing until the knock sensor is repaired
i would check your tps
www.supratsrm.com
under efi> throttlebody
Old 09-28-2005, 06:57 AM   #3
kewlcoconut
Ok, well I guess that I read the codes wrong when I diagnosed it myself. I thought I was getting the TPS and Knock Sensor code. It was only the knock sensor. My mechanic fixed the knock sensor. Apparantly it was in two pieces and looked like it had been hit or something. The car runs better with the sensor in place, BUT i still have that problem!
I am stumped on what it could be. I have no engine light on, but it still breathes like it has severe asthma or something. I thought it might be a battery recharge problem, and i checked everything. The alternator is only a few months old and it was doing this before I got the new alternator. So that rules it out. The battery is fairly new as well. And the throttle body was cleaned out as well and the TPS is working fine. So its not a problem with wiring, at least i dont think it is. And I checked over and over for cracks and holes in vaccuum tubes and the intake tube. I am STUMPED!!!!
EDIT
Could this just be a really bad case of heatsoak?? I sure dont have problems with overheating or anything. Im running the stock fan in my 7MGE and it seems fine. But when i turn it off for a while and turn it back on about 20-30mins later, its like the battery isnt charging, or its just overheated or something is causing it to breathe and die like it does. I dont know.
Guidance please?
Old 09-28-2005, 12:13 PM   #4
recheck diagnostic codes and post up the numbers
Old 09-28-2005, 02:30 PM   #5
rnoswal
rnoswal's Avatar
You could have something blocking the intake somewhere, OR you may have a blocked cat. converter or muffler. Timing could be way too retarded. Thes cars do slip their timing belts after they get old and some of the time the car will move but barley, or not at all.
All I can think of for now. S_girl has a good plan too.
Russ
Old 09-29-2005, 04:56 PM   #6
supraflymkiii
supraflymkiii's Avatar
supraflymkiii is on a distinguished road
Smile
This same problem happened to me right after I put my new engine in. I thought it had something to do with the MAFS but it turned out that the dashpot was out of adjustment. So if you just mess around with the adjusting screws on the throttle body you should be able to fix the problem.
supraflymkiii is offline   Reply With Quote
turbo? Knock sensor? running lean? west_side_supra MKIII Supra 19 02-01-2009 07:28 AM
Bad Knock sensor TWRViper MKIII Supra 5 08-31-2005 09:24 PM
