Old 08-05-2011, 03:18 PM   #21
dylansword
dylansword is on a distinguished road
Does anyone know how much boost you can get out os a 57 trim ct26?
dylansword is offline   Reply With Quote
Old 08-05-2011, 05:17 PM   #22
El Supracabras
El Supracabras's Avatar
That is a question I would ask the supplier of the turbo. They would be able to tell you much more accurately what the max recommended pressure for their turbocharger would be.
Old 08-07-2011, 03:20 PM   #23
MA70-3.0GT
MA70-3.0GT's Avatar
Originally Posted by El Supracabras View Post
That is asking alot from a stock ct26 don't you think?
Well, I ran what I believed to be the stock CT26 up at 11psi for just over a year (and the shaft already had more than spec'd play when I got the car with it's BHG). I expected it to last a few hundred miles before the smoke started but in the end it lasted over 10k miles & was still boosting strong & smoke-free when a failed BOV signal pipe that killed it in one fell swoop of surge...
That said looking at pics now I'm not so sure it was a stock supra CT26, compressor housing looks too big.
Old 08-07-2011, 09:38 PM   #24
PSI doesn't mean all that much when it comes to turbo selection... Actually, it means very little. Think about the difference between a 6' tall industrial air compressor vs a small bicycle tire pump... both may be able to handle 150psi but the bike pump is going to have to work its ass off to fill the same size tank that the larger compressor could fill in a couple seconds.
Without getting into all of the specifics I'll just say that a CT-26 with an upgraded compressor will work quite well for what you want while maintaining a bolt-on setup and quick spool. 57 trim will run efficiently past 350RWHP.
Old 08-09-2011, 03:41 AM   #25
dylansword
Thanks very much!
Old 08-09-2011, 04:17 AM   #26
dylansword
Any one have anything to say about this t61?
http://www.cxracing.com/mm5/merchant...t_Code=TRB-T61
Old 08-09-2011, 04:46 AM   #27
Mk3FirstCar-Mike
Mk3FirstCar-Mike is on a distinguished road
Just my two cents here, but I'd try to find one with about a .7-.8 A/R, ball bearing and (external) wastegate. Ball bearing turbos are more durable than journal bearings. That turbo is a fairly good size for street driving, though. It should spool up nice and quick. The only thing that's stopping me from liking it is the internal wastegate and not knowing who makes it.
- Other than that, for the horsepower you're wanting, it should do just fine.
Mk3FirstCar-Mike is offline   Reply With Quote
Old 08-09-2011, 05:01 AM   #28
dylansword
I don't want to sound stupid, but what's the differenct between internal and external wastegate? I see a wastegate on both of them. Is the boost still adjustable? Thanks very. Much
Old 08-09-2011, 05:53 AM   #29
Mk3FirstCar-Mike
Don't worry about feeling stupid; I'm stupid 70% out of the day. Anyhoo, external wastegates are more precise and more responsive. They're also easier to work on and provide slightly less backpressure, IIRC.
Also, internal wastegates CAN be tuned, but you can't tune them below a certain boost pressure. However, they can be tuned up by using a boost controller.
Last edited by Mk3FirstCar-Mike; 08-09-2011 at 06:20 AM. Reason: Typo - More Information Added
Old 08-09-2011, 04:37 PM   #30
dylansword
Okay, so there still good, just not for getting big numbers, and super precise tuning? One of my buddies has a t3 that he'd sell me for cheap. Anyone ever used one? Any recomindations?
