Old 08-02-2011, 04:42 AM   #1
icey756
Default Speaker Questions
I was taking off my door panel and i noticed the speaker was in a black plastic box which i guess is known as an acoustic box. I'm getting new speakers for my car. Do i still need to use that box or can i just mount the speaker right to the metal the box was screwed to? just wondering if that box would make a difference is all or if i should just cut the box to fit the speaker size. Also i heard i might have 6 speakers????
Old 08-02-2011, 08:05 AM   #2
I think 89 is when they introduced the 6 speaker system. You should keep the plastic box if possible, it will improve the sound quality and make it easier to hear the speakers over installing them in the empty space
Old 08-02-2011, 12:17 PM   #3
El Supracabras
El Supracabras's Avatar
Keep the plastic enclosures, they're necessary to get any "decent" sound from a 4" speaker.
Old 08-02-2011, 05:55 PM   #4
icey756
should i cut into the plastic box to fit a bigger speaker in?
Old 08-03-2011, 01:28 AM   #5
907mge
907mge's Avatar
Why not just install a higher quality speaker than stock for the high range and use a sub and amp for mid and low range . I know at least in the back the speakers are prone to become torn.
Old 08-03-2011, 06:51 AM   #6
icey756
i did plan on putting something like 6x9 in the front without the box. but im not sure yet. the back is just crappy because you dont have a lot of room to work with where the speakers go. and im not building separate boxes for them either cause that would make it look shitty i think. What if i go with high quality speakers that actually fit the front and back? i know the back needs a little bit of modification either way but if the speakers were good enough i would think they would sound good
Old 08-03-2011, 07:15 AM   #7
I think that's what 907mge was saying, use a high quality stock sized speaker in the factory enclosures.
The problem is that it's basically impossible to find a 4" speaker that will sound good and produce decent lows and mids, which is why most people run an amp and sub(s) to take care of them. Most aftermarket radios have a setting in them to adjust the HPF and LPF, so you can fine tune what sound frequencies you want going to subs/speakers
Old 08-03-2011, 05:05 PM   #8
icey756
ahhh i think i got er now. So if i did go with speakers that will fit stock ( no mods other than a tad in the rear) then i should get a sub for the lows? Is that what ur sayin
Old 08-03-2011, 08:24 PM   #9
A sub is good for the lows, but you'll still find the mids left wanting. Cutting the stock front box and installing 5" or 5 1/4" speakers is a step up. Upgrading to the '91+ door speaker boxes which house 6.5" speakers is the best option if you're still looking for a semi-factory finish. The '91+ door panels have larger speaker grills to accommodate the air flow... If you don't swap in a set of them I recommend you consider a custom solution to open up the grill more.
Old 08-04-2011, 05:22 AM   #10
icey756
Thanks cre. u da man
How many speaker does a 93 toyota supra have? Bl@ckh3art MKIV Supra 5 05-22-2011 02:46 AM
1985 front speaker issue Justme MKII Supra 2 06-19-2009 03:47 PM
Right rear speaker tower? schneid MKIII Supra 1 09-28-2006 11:31 PM
