Old 08-04-2011, 12:15 AM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
Default ign timing?
alright let me start out with this. yes I used the search button and looked through the FAQs I even googled it.
now that thats out of the way heres the question
I know that when you jump the box the timing is 10btdc on the 7mgte, But the engine is not in a supra and has a full wire tuck (which means no diag box) so what am I supposed to set the timing at without the jumper anyone know?
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 08-04-2011, 12:28 AM   #2
El Supracabras
El Supracabras's Avatar
That's a tough one. Why would you do that? It's not so bad, those wires eventually went to the ecu. You just need to find out which ones they were at the ecu and jumper them there.
Old 08-04-2011, 01:03 AM   #3
thats alot easier said then done every wire was cut at both ends and ran individually to keep them out of sight and I did this because I didnt want to see them and because the wires were pretty much all shot beyond saving. I figured someone whose timing is know to be good could just slap a timing light on their engine and let me know what it shows at idle. my car runs it just seems a little sluggish lately it was spinning through 2nd gear a few days ago now it catches about half way through i havent lost any boost and have no misses etc. which points me to timing but the engine only has 400 miles on it so id rather not just go advancing the timing without atleast some sort of baseline of what to look for.
Old 08-04-2011, 01:41 AM   #4
El Supracabras
I'd still look for the pins in the ecu. I wouldn't want you to mess up the engine. What year is the ecu from? We can try and find a diagram. The engine wont show you base timing unless the pins are shorted, otherwise it's just going to show you the corrected timing. Also it would be good to be able to check VF voltage to help with tuning it and if there are any codes stored. You can make your own diagnostic box to do all of this.
Old 08-04-2011, 02:00 AM   #5
I've got a bunch of diagrams I just figured it'd be easier this way than hacking into my wires again i guess i can just put in some t-taps with spade connector ports as long as its not one of the wires i removed completely
Old 08-04-2011, 02:16 AM   #6
El Supracabras
Try it. If you need help or get stuck on something, just post. The harness can be re-pinned if necessary.
harmonic balancer came off crank shaft help? wishiknewmore MKIII Supra 3 04-15-2011 11:04 AM
Timing Knock or tap batmmannn MKIII Supra 5 06-02-2010 03:20 AM
Exhaust vs Timing, something else? Krem MKIII Supra 9 03-18-2010 02:39 AM
timing problem with knock robertsws MKIII Supra 1 09-04-2009 03:40 PM
Timing question Kevin MKIII Supra 3 07-10-2009 07:52 PM
