Old 08-09-2011, 12:03 PM   #1
turbonicsperformance
Default MAFT questions?
any running a MAFT system as a speed density? I saw some videos of cars running a maft system as a speed density is there an additional attachment for this or is it just for other cars like dsm etc.? either way my kvafm went out and a friend has a used MAFT for sale cheap so im gonna pick it up and go MAFT. i was just wondering how to go about using the MAFT as a speed density.
Old 08-09-2011, 12:18 PM   #2
El Supracabras
El Supracabras's Avatar
You need MAFT PRO to run in speed density. It is not a function of a regular translator which will only allow the use of a larger GM MAF sensor instead of the KVAFM. It also allows you to run in "blow through" configuration which means you can vent your BOV without stalling.
CRE used to have a bunch of info in his sig about it. Hopefully he will have something better to add.
Old 08-09-2011, 11:32 PM   #3
alright thats pretty much what i thought but i wasn't sure i dont really need any more info on it i have a buddy selling me a maft system with gm maf all ready to go for 150 a little later on i just thought if i could run a speed density id do it if possible but its just a 7mgte specific maft not a pro
Old 08-11-2011, 07:22 AM   #4
The original MAF Translator and the MAFT Gen II only support MAF conversions; No S/D or solo MAP setups. That said, there's a lot to be said for the GM MAF... They're still a much preferred meter for upgraded setups. The KVAFM is an EXCELLENT meter but the minute you want something a good deal larger or want to run blow-through, you're screwed (You can run a MAF in a blow-through setup with little difficulty).
7mge build with some questions. 87hilux7mge MKIII Supra 34 06-11-2014 09:04 AM
1jzgte Swap questions!! Travis89Turbo MKIII Supra 1 08-16-2010 12:34 PM
Some questions about my 1988 Supra... Somajunkie Non-Generation Specific Questions 11 06-18-2007 05:47 AM
