#11 |
Supra Forum Moderator
from what I remember from past posts that there are two types of fans you can install.. thermostat controlled ones and electrical switch types.. I believe the general consensus was the thermostat controlled ones are the way to go.
Am I close on this. It's been awhile.
![]() 92 Ma71 7mGTE Auto. SafcII Supra FAQ Supra MKIII FAQ Classified Section guidelines : |
#12 |
![]() Toyota Racing Development Join Date: Apr 2007
If his existing fan is working then adding another isn't going to fix anything.
The fan clutch should get harder to spin the warmer it is (with the engine off). If it's as easy to spin when cold as it is when the engine is hot then it's bad. It should never spin completely freely nor refuse to be moved by hand. http://www.popularmechanics.com/cars...enance/1772922 http://www.ehow.com/how_5086903_test-fan-clutch.html There's also the infamous newspaper diagnosis technique but I'm not going to advise that myself... You can find it on YouTube. It's safe enough unless you're an idiot or happen to get startled and throw your hand into a moving belt...
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#13 |
One final question, i want to bleed my cooling system (when i turn off the engine i hear a bubling sound coming from the radiator)...how should i do it? Is there any tutorials available??
Thanks in advance for your help! |
#14 |
i got a 87 turbo which came whith one electrical fan and the heavy mechanical fan, so i went to the junk yard and found a N/A 89 i belive and took the shroud and the twin electrical fans, i spliced a few wires, swaped the shrouds and now the fans work great. its was cheap easy and thankfully the 89 shroud can retrofit the 87
#15 |
mine does the same thing as well. i put one of thes pressure caps whith the little pressure relive tabs on it when ever i release the pressure my overflow tank starts to gurgle and bubble. Doesent seem to hurt it any just wierd
#16 |
Here is how to burp ur cooling system. Its in the FAQ. When i joined the forum i read almost all the FAQ's. It gives you alot of good info believe it or not.
http://www.toyota-supra.info/forums/...r-bubbles.html This is the way that i know of on how to "bleed" ur system
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans. |
#17 |
Okay thanks for the info. Ill check out the faq's
Thread Tools | |
Display Modes | |
electrical problem! I think!!!!!help!! | Boostcrazy61 | MKII Supra | 0 | 08-21-2009 12:08 AM |
Frustrating electrical problem | thebobfoster | Non-Generation Specific Questions | 1 | 05-30-2009 09:16 PM |
Needing some electrical help | happysupraowner:) | MKIII Supra | 3 | 04-19-2009 01:16 AM |
Oil Pressure...Mechanical or Electrical??? | Luvs2slide | MKIII Supra | 5 | 08-23-2006 12:42 AM |
Intermittent Electrical Problems on a ’93 MKIV | gjs_cds | Shops & Part Reviews | 0 | 05-22-2006 02:39 PM |
