Old 08-11-2011, 08:48 AM   #1
supradestro
supradestro is on a distinguished road
Default Power steering hose problem?
The other night after taking a ride in my 89 NA and backing in into my driveway, I noticed a drip trail that wasn't water. It felt & smelled like ATF fluid.
Sure enough, the power steering reservoir was almost completely empty and there was a lot of my ATF fluid on the garage floor. After inspection, I noticed that the hose coming off of the reservoir seems to be wet & leaking near it's bottom most connection.
In the picture I have attached, it's the hose on the right (the smaller one) that I believe is faulty. How difficult is it to swap this guy out? Can I use aftermarket hoses on this or only OEM? What else can and should I be looking for while I'm down there swapping this one out? Do these hoses normally go fubar or should I be checking out something else?
Thanks a million!
Name:	supra ps hose right one.jpg
supradestro is offline   Reply With Quote
Power Steering Pressure Hose Step by Step SilverMK3 MKIII FAQ 1 02-20-2011 09:38 PM
Power steering problem JOEYP3RD Non-Generation Specific Questions 1 06-05-2009 05:19 AM
Pressure Hose on Power Steering, first Supra and first post here. ddouglas77 MKIII Supra 4 12-01-2008 04:15 AM
Picture? Power Steering pressure hose ptomko MKIII Supra 4 10-08-2008 02:19 PM
Replacing Power Steering Hose - need help xTomKx MKIII Supra 15 01-15-2008 06:34 AM
