#1 |
Hi guys!
I have a few questions about the ECU on these engines and if I were to land a 7M-GTE engine into a car that came stock with 7M-GE, if when swapping the ECU's would I have to re-wire all the wiring harness, or if I could just plug and play because of the similar engines. What all would I need to do, and if you had any advice, what would you give me? I want to swap because the GE car is in tons better shape and is more clean. Thanks much!! Colton |
Thread Tools | |
Display Modes | |
7mgte swap vs 1jz swap | Supra Saiyan | MKIII Supra | 15 | 04-24-2012 02:58 AM |
MKIII 1JZGTE Swap How To! Pic Heavy | Travis89Turbo | MKIII FAQ | 12 | 03-16-2011 05:22 PM |
all their is to know for a 7mgte swap | mkiii<3 | MKIII Supra | 0 | 10-03-2010 10:23 AM |
1JZGTE swap question | supradaddy0803 | MKIII Supra | 1 | 04-12-2007 04:56 PM |
2JZ Motor Swap | MDellboy420 | MKIII Supra | 3 | 09-11-2006 06:19 PM |
