#1 |
Okay, I have a 3inch down pipe and 2.5inch exhaust. I went up to summit racing to buy gaskets for my exhaust but they had none that would fit my car......I don't know how many other people have this problem but this is how I went about it and maybe it might help someone
I purchased a sheet of Mr Gasket 24inches long and 8inches wide ![]() ![]() I then traced every line, when doing this pay extra attention to the bolt locations and holes.....They have to be perfect! I used industrial wire snips and it leaves kind of a jagged edge. I will show you what I did to take care of that. ![]() ![]() So then I placed the gasket in a clamp and used a drill to poke holes where the bolts will go through and where I will snip a hole out of the middle for the exhaust ![]() ![]() To smooth out the edges I used a zip tool with sand paper round bits....It takes a while but I believe to have a good seal it had to be done ![]() ![]() Here is what I ended up with...Not bad for my first time I think....Going from left to right you can see I did get better and better as I went on ![]() ![]() I actually had fun doing this....Nothing like custom fabricating your own parts....Even if it is just some gaskets lol
IF IT AINT A SUPRA IT AINT SH*T!! 87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch 95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold) 89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold) (Sold) |
#2 |
looks pretty good! that and some copper spray, you shouldnt have any leaks. good job man.
87 toyota 4x4 single cab short box pickup, 7MGZE. |
#3 |
#4 |
Thanks......That middle gasket in the last pic after I took that pic I had to re-do the bolt holes.....I think that's what took the most time man the bolt holes have to be perfect.......But so far no leaking exhaust from what I can tell.......That 3inch down pipe and 2.5inch exhaust made a hell of a difference!......Only problem I had was I could not get the turbo elbow off so I had to leave the stock one on there and couldn't use the gasket that came out the best......One day when I have time I will try to get it off again
Thread Tools | |
Display Modes | |
Mk3 exhaust upgrade for under $50.00!!! | batmmannn | MKIII Supra | 12 | 06-04-2010 01:52 AM |
Exhaust system & components | Krem | MKIII Supra | 6 | 05-27-2010 12:35 PM |
Exhaust for 7MGE | XtreeX | MKIII Supra | 19 | 03-25-2010 01:39 AM |
Does the exhaust manifold need to come off to replace head gasket? | BillW | MKIII Supra | 1 | 10-02-2009 12:19 AM |
