Old 09-05-2011, 08:20 PM   #1
mof920
mof920 is on a distinguished road
Question MKIII Headers 7MGE
I finally fixed my head gasket problem. Yup. Took me several weeks to get it done. Anyhow, I'm looking for performance options, mostly in agility. Finding suspension mods and kits are easy however, what I'm having a lot of trouble finding is performance upgrades for my N/A. I'm not looking for much. I just want bigger headers (Intake and Exhaust) and a good intake system. I know it's not a lot of power I ask for. I can't find a thing. Just OEM replacements. I'm not worried about price. I just want to know where to look. Also, any tuning shops in South Cali?
mof920 is offline   Reply With Quote
Old 09-07-2011, 03:03 AM   #2
Busted Knuckles
Busted Knuckles's Avatar
I've seen many headers on Ebay for 7M-GE N/A.
Also Horsepowerfreaks.
Other sources available with a google search....
As for intakes, the 1JZ to 7M intake is popular, but requires very good aluminum welding..
And, for N/A, this set-up is WICKED SICK!!!
Too bad a turbo upgrade packs way more punch than any of this. I'd save your money for a 7M-GTE or a 1JZ/2JZ swap.
Old 09-07-2011, 08:17 AM   #3
Actually this is common on boosted engines, not N/As due to some VERY significant engineering and blue printing required to ensure that no cylinder is starved at any point. Then there's the whole issue with losing the ACIS system (goodbye low end torque). If you know someone with the mad skills to design, blue print, virtual flow test to get past hurdle #1 you could use a dual runner setup like the 3S-GTE uses to make up for the torque losses.
The best thing you can do for the N/A is either leave it completely alone, or convert from the VAFM to a 2.75" MAF or a MAP based setup. Ceramic coating on all intake and exhaust components would be good too.
As for the exhaust, don't go too large or you're actually going to hurt performance. I'd say nothing bigger than 2.5" dia and as straight as possible. High flow cat, true helmholtz resonator (like the ones Aero Turbine make) and a good quality straight through muffler (love dem Borlas!).
Old 09-08-2011, 03:38 AM   #4
Sonyps307
On eBay obx makes a nice stainless steal header. But if u get it I would have it heat coated or wrapped it gives off alot of heat and it comes in to parts I would get them weld and have the o2 sensor bung moved up. For the intake u can have a shop weld up a pipe that goes from the throttlebody to afm. Then u can put a k&n filter on but put a box around it or get it into the fender to keep heat away.
Old 09-08-2011, 04:56 AM   #5
K&N is crap (not just because of the KVAFM killing oil)... I'd recommend AEM, Amsoil or Apex'i air filters... AEM is the least expensive.
Tags
7m-ge, 7mge, headers, intake, performance
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
'87 mkIII 7MGE Rebuild. Pijus Show n Tell 6 10-11-2010 11:58 PM
7MGE Head Swap 7MGTE87 MKIII Supra 3 03-27-2010 06:39 AM
86 MkIII 5 spd 7MGE for sale in Northern VA (Stafford/Fredericksburg area) ricangsxrdude MKIII Supra 0 11-12-2008 02:38 PM
