-   -   turbo remont (http://www.toyota-supra.info/forums/mkiii-supra/19631-turbo-remont.html)
Life is Supra 09-06-2011 02:12 PM
turbo remont
Hi,I have a problem taking off the turbo from the engine.Can someone tell mi the order or send mi a pictures of have to remove a pipe belowe and in between the hot and cold part of the turbo where oil goes to the engine???
cre 09-06-2011 08:27 PM
Sadly, there is no easy way. I'm certain that Toyota only intended for the turbo to be removed with the engine out of the car. The only two methods I've found to date are: Unbolt EVERYTHING and wiggle, pull, pry tug and swear repeatedly until you bleed enough to appease the 7M gods. OR cut the hard lines and replace them with a flexible hose kit when you put it all back together.
