-   -   A/c compressor won't kick in after work perfectly (http://www.toyota-supra.info/forums/mkiii-supra/19632-a-c-compressor-wont-kick-in-after-work-perfectly.html)
Sonyps307 09-06-2011 03:04 PM
First off my a/c coil burnt up so I replaced it. Then after that it still would not work. so then I found that the 10amp on pass side blow change it. Then the a/c was working great for 3 days. Till the 10amp blow again so I put a 15 amp in it and nothing a/c don't work. Also the system is full.
I checked already The CB, the relay under the fuse box out in bay, 15 amp cig, dual pressure switch. The only thing i didnt check was the amplifier but I don't know where it is or what is looks like.
cre 09-08-2011 05:25 AM
Is the fuse blowing immediately? Have you tested for shorts to ground? What "A/C Coil" are you referring to? The blower resistors?
The A/C Amplifier is behind the ECU: http://www.cygnusx1.net/Supra/Librar....aspx?S=AC&P=8 A real pain to get to if I recall.
Is the blower working?
Sonyps307 09-08-2011 06:14 AM
The blower works fine. The fuse blow 3 days after working perfectly so i replaced it and havnt check it since. The coil I'm taking about is the one on front of the compressor the one that engages the clutch. I have not check for shorts yet.
87hilux7mge 09-11-2011 04:06 AM
i believe he means the magneto. check to see if you clutch is bent or deformed at all. more likely tho the magneto is pulling too much power, fried the fuse and then burnt the link at the compressor.
idk, i try not to deal with a/c systems too much, they just make me mad. so i take them off and roll the windows down.
