Old 09-06-2011, 05:55 PM   #1
turbonicsperformance
Default clutch question
been finding WAY too many part #s for the same part online so basically all i need to know and its probably been answered but i can't find it is ...
will the clutch disc for a r154 work on a w58?? my ACT solid disc is slipping so i'm going to a 6 puck disc and all i can find is for 7mgte which is supposed to have r154 behind it...
thanks for any help.
Old 09-06-2011, 08:22 PM   #2
No, it won't work.
Old 09-06-2011, 10:42 PM   #3
thanks. is it the clutch diameter, or something else? i saw that they are both 21 spline shafts but thats all i could find out.
Old 09-07-2011, 08:03 AM   #4
The diameter is larger on the R154 side. Doing a little digging I get results from some folks I trust saying that some discs will interchange without issue but no one seems willing to actually bet money on it. So.... I'll amend my initial response to a great big: Maybe.
I remember someone trying it once (I think it was an owner on SF) and having significant rubbing/scraping problems with a performance clutch disc spec'd for a GTE in a GE clutch. Not the prettiest thing to find when you have to pull the transmission a second time I'm sure; But he was pushing his luck, it was a several millimeters larger in diameter and there was some other issue with the pad overreaching the flywheel's friction surface (might have been an aftermarket flywheel). I'm sorry, I just can't remember all the specifics; I just decided that it was one of those things not worth screwing with.
I'd just contact the manufacturer and get dimensions and compare them to the dimensions of the OEM GE disc. If the diameter is just a few more millimeters then I wouldn't sweat it.
What are you running that you current clutch is slipping? Unless it's old or damaged the GE doesn't put down anywhere near enough power to win that fight... not even with every mod you can throw at it. The stocker will hold more than the transmission is capable of, I've been there done that.
Old 09-10-2011, 02:05 AM   #5
i have a 7mgte in my miata with cp pistons studded mhg maf-t 3 inch custom dp fmic and 2.5" piping and 550 ccs running 15psi from the "gte-u" turbo (i guess... idk exactly but the compressor wheel is 5mm larger than my friends and another ct26 i have lying around as well as havind 6 dual fins rather than 5) i have the ACT stage 2 street clutch and in 3rd or above under boost it slips quite a bit the pressure plate has good pressure and only like 8k on it... it held up to 6 psi fine when i went to 15 it started slipping and now that it has glazed it slips all the time even lowering it back to 10psi i'm just running a w58 for the time being until i locate a r154 plus the miata only weighs 2360 with me and a FULL tank of gas lol so the w58 should take quite a bit it just spins the tires instead
I found the disc i needed though part # 6236007 6 puck unsprung or 6236207 6 puck sprung
any experience in possible holding gain between the 6 puck and street disc?
Old 09-10-2011, 05:29 PM   #6
You should be spigging tires all day long, not your clutch. I know people with similar setups who get away with launching all day on stock Toyota clutches in MUCH heavier MKIIIs.
At any rate yeah a 6 puck disc and a higher pressure pressure plate would be the next step up. Do NOT use an unsprung disc!
MK III turbo clutch setup question. DarkSupra2.5 MKIII Supra 5 02-10-2010 05:58 AM
clutch question a7morelli MKIII Supra 1 07-18-2009 10:36 PM
Clutch wear question suprabahamut Non-Generation Specific Questions 2 09-14-2008 04:20 PM
Clutch Master Cylinder question. 1989 Supra. PFlanagan MKIII Supra 4 08-07-2008 08:20 PM
clutch question !! 88Supra86 MKIII Supra 5 09-26-2007 01:47 AM
