#1 |
Hi to all, my 87 7mge is not starting. I have replaced the maf with a rebuilt one. I have also bought a used distributor and I another used ignitor with a new coil. Now ever since the car hasnt started I have switched the sparkplugs to ngk iridiums and I also got a set of semi used ngk cables from my buddy which are on the car. Since my throttle body positioning sensor was broken and cracked and the spring was seized, I replaced it with a used one that looking clean and the spring had good tension on it. Now I removed the top half of the timing cover to ensure that time was correct when I set the crankshaft pulley at zero and it was so I made sure that the distributor was set by the markings on the distributor body to the shaft hole. Now the car seems like it wants to start but it turns off If I give it gas while the car is trying to start it dies can anyone help me with this? I need my car to go to school which happens to be UTI lol it's my first year going. Need help please can anyone tell me what to check for?
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
Have you checked for diagnostic codes? See the MKIII FAQ section for details.
Check that the grounds for the EFI system are CLEAN and well connected. There are a couple grounds bolted to the passenger side of the head toward the back (cyl #6) and a couple more on the driver's side which are bolted to a stud beneath the upper intake plenum (between cyls 5 and 6).
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
Okay so I hav checked the grounds and they appear to be good I have checked them to be sure tho. How ever I did manage to get the car started with a can of starter fluid. Now I checked the fuel pump relay resistor and if I'm not mistaken it shouldn't read more than .7 ohms if it's good. But my is reading 1.1 ohms. I did order a replacement. Should this be the problem to not starting the car? I did narrow it down to a fuel issue but is the relay resistor the only problem? I would grateful appreciate your help and input in regards to this matter thank you in advance.
Can anyone please inform me on how to check the fuel pump with out dropping the tank and removing the fuel pump Thank you |
#4 |
Super Moderator
You can override some of the fuel pump circuit by placing a jumper wire in the diagnostic box between FP and B+. This should cause the fuel pump to continuously run when the key is in the "on" position.
If you can't hear the fuel rushing through the fuel rail, you can take the fuel filler cap off and listen for the pump through the filler neck
1989 7MGTE R154 Targa Top White Package w/Blue Interior Driftmotion 57trim CT26, Upgraded Intercooler, 2.25" Hard Pipes, 3" Turbo Back Exhaust with Test Pipe, HKS VPC w/GM 3 bar MAP sensor, APEXi S-AFC, Walbro 255lph fuel pump, ProSport EVO Series Boost / Fuel Pressure / AFR gauges, Lotek a Pillar Gauge Pod, HKS Type 0 Turbo Timer, Eibach Lowering Springs, Tokico Illumina II TEMS struts, custom powder coated Motegi Racing TrakLite wheels |
#5 |
Okay so I tried the jumper technique and I did start to hear a buzzing noise coming from around the fuel rail but the car still turns on but turns off immediately I believe I'm still not getting fuel. So no change after the jumper technique. Now after trying to start the car for a while I do get a puff of white smoke out of the throttle body.
Any input would be greatly appreciated. Thank you in advanced. |
#6 |
Did you try running the car with the jumper in place? Test the AFM, pay particular attention to the FC switch.
#7 |
Okay so I decided to change the fuel pump and when testing the pump out of the tank it would be engage but it would be really weak compared to the new one. So I again set the cam shafts and the crank shaft at zero and realigned the distributor. So we gave it a few tries and bam it started so now we left it on for a while and when I would give it some gas it the rpm would fluctuate
Thread Tools | |
Display Modes | |
1986 7mge supra not starting | Jrsinnovations | MKIII Supra | 2 | 08-15-2011 07:05 PM |
7mge hp increase info | 907mge | MKIII Supra | 14 | 02-05-2011 03:03 AM |
7MGE Head Swap | 7MGTE87 | MKIII Supra | 3 | 03-27-2010 06:39 AM |
starting motor | Dom | MKIV Supra | 3 | 04-05-2007 01:57 PM |
engine noise car dies after starting | tex1116 | MKIII Supra | 7 | 11-18-2005 06:47 PM |
