Old 09-29-2005, 04:58 AM   #1
dcrusupra
dcrusupra's Avatar
Default Metal to Metal
I'm hearing this clanking sound everytime i hit a bump. I was thinking it was the front end bushings. Then when i turn the wheels i hear it but not at violent which leads me to think its the wheel bearings. I just replaced the rack and pinion so that eliminates some theories. I'm lost and have no clue what it could be.
Old 09-29-2005, 01:31 PM   #2
rnoswal
rnoswal's Avatar
Check out the ball joints, sounds like it could be one of those.
Russ
Old 09-29-2005, 06:46 PM   #3
Dejvid1785
Dejvid1785 is on a distinguished road
Did you replace that rack and pinion yourself? If you did, how hard was it? Any advice would be good, i'm getting ready to replace mine.
Dejvid1785 is offline   Reply With Quote
Old 09-29-2005, 11:44 PM   #4
mrnickleye
mrnickleye's Avatar
Easy job.....
Back to noise...possibly the struts (inside play).
Old 09-30-2005, 02:11 AM   #5
dcrusupra
dcrusupra's Avatar
No i had pep boys do it. My rack bushings were damaged to shite and the only place i could find them was at a dealership and they had to order it from the warehouse. So it took a few days.
Old 09-30-2005, 02:11 AM   #6
Dejvid1785
I know u don't seem to interested to help me out but i'm gonna ask anyway. Is there anyway u can kinda sum up what u did first so it makes it easier on me, i'd appreciate it.
Old 09-30-2005, 02:06 PM   #7
rnoswal
rnoswal's Avatar
Make what easier on you? Which part are you refering to? Most don't mind helping at all, you just have to explain clearly what it is you need help with. Let us know.
Russ
Non Metal Head Gasket 1988gte MKIII Supra 2 10-16-2007 04:31 AM
Hks Bead Metal Head Gasket Bore Size Help!!!!!!!! papaleach MKIII Supra 5 11-17-2006 11:27 PM
Metal in oil G-string MKIII Supra 1 04-03-2006 10:44 PM
