Old 09-22-2011, 05:59 AM   #1
87hilux7mge
87hilux7mge's Avatar
as far as my research has gone, the 6m lower end is the same as the 7m. couldnt find info on the timing setup. the pistons are definitely different, but couldnt find the comp ratio either.
i know all the parts for my jdm 7m had 6m stamped on them (rods, crank) so id say aside from the pistons, youd prolly be solid.
Old 09-22-2011, 06:21 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
Yeah, that's pretty much what I came up with. Only reason I bring up the crank timing gear is because I'm fairly certain the 5M uses a timing chain and not a belt.
EDIT: Turns out the 5ME uses a chain, 5MGE uses a belt. So the 6M bottom end is probably good to go without modification.
Old 09-22-2011, 06:29 AM   #3
87hilux7mge
i was gonna say..."mmmm....i wanna see the 5mge's uve seen!" haha
re: 2jz swap into mkIII supra88 MKIII Supra 1 05-11-2011 05:57 PM
MKIII 1JZGTE Swap How To! Pic Heavy Travis89Turbo MKIII FAQ 12 03-16-2011 05:22 PM
doina 2jzgte swap into 87 mkiii need help cooks87ttopsupra MKIII Supra 0 12-28-2010 03:46 PM
MKIII , GE to GTE swap Idaho MKIII Supra 0 02-02-2006 02:47 PM
