Old 09-20-2011, 12:07 AM   #1
Nitetrpr
Nitetrpr is on a distinguished road
Default mass air flow sensor
Can any tell me if the sensor from a Lexus will transplant onto a 7mgte from 1987?
Nitetrpr is offline   Reply With Quote
Old 09-20-2011, 03:04 AM   #2
turbonicsperformance
turbonicsperformance is on a distinguished road
yes the sensor itself is the same between the 7m and the 1uz but you dont want to use the housing unless you have injectors to match.
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
Old 09-20-2011, 05:46 PM   #3
Nitetrpr
Thank you If I were to use the housing what injectors would I need and would anything else need to be changed? What is the outcome more HP?
Old 09-21-2011, 05:38 AM   #4
87hilux7mge
87hilux7mge's Avatar
550cc injectors is the common upgrade with the 1uz afm housing upgrade.
the housing allows more air to enter the engine, basically unmetered, because the housing is larger. if you didnt do injectors, you would run lean at WOT. there are several threads on here if you search "lexus afm and 550's".
and yes, power is the gain. how much depends on how much you put in. just the afm and 550's, a little.
add a piggyback controller and wideband o2, the power potential increases.
Old 09-26-2011, 01:07 PM   #5
El Supracabras
El Supracabras's Avatar
The outcome would be you could run more boost before hitting fuel cut. If you have it tuned properly, yes, the extra boost will yield extra HP. The correct injector size needed would be 560cc. 550 is more commonly available and close enough.
This is not a "slap it on and crank the boost" mod. Fuel pressure, AFM bypass screw and injector size all need to be adjusted for this to be an actual "upgrade". If you're not ready to get the injectors and everything else, don't use the housing.
Mass Air flow sensor phill_54321 MKIII Supra 9 07-04-2011 11:38 PM
Mass Air Flow Sensor? SuperSpartan Non-Generation Specific Questions 0 05-03-2008 07:51 AM
