Old 09-27-2011, 12:59 AM   #1
nessies2003
nessies2003 is on a distinguished road
Default Transmission Troubles
My 89 Toyota Supra Turbo (automatic) has been showing some signs of transmission problems, but I'm pretty sure it was replaced in the last 30k miles.
About 6 months ago or so, the engine started doing this sputtering thing right after ignition until the car had run for a bit. That issue hasn't really been a problem and could not be duplicated at the mechanic.
Recently though, when I'm driving about 35 mph, the transmission tries to switch gears and never finishes. The engine just keeps reving and accumulating rpm with no gear switch. I've found that turning the Overdrive off has allowed me to drive when this happens, but it is clearly not a permanent solution.
I checked my fluid today after driving home on a reasonably flat surface, and it looks like it is slightly low for being hot (at the bottom of the HOT marker). It's also brownish.
Is it possible that I just need to add or replace fluid, and if so, should I get a full flush? Any other possibilities?
Thanks.
nessies2003 is offline   Reply With Quote
Old 09-27-2011, 01:37 AM   #2
Mk3FirstCar-Mike
Mk3FirstCar-Mike is on a distinguished road
(Dextron II Automatic Transmission Fluid)
I believe it's supposed to be a very light brown.
Replace it. That's pretty much the #1 cause for A/T problems.
"Faster, faster, faster, until the thrill of speed overcomes the fear of death." – Hunter Thompson
"It is amazing how many drivers, even at the Formula One Level, think that the brakes are for slowing the car down." – Mario Andretti
"Speed has never killed anyone, suddenly becoming stationary… that’s what gets you." – Jeremy Clarkson
"When I raced a car last it was at a time when sex was safe and racing was dangerous. Now, it’s the other way round." – Hans Stuck
Mk3FirstCar-Mike is offline   Reply With Quote
Old 09-27-2011, 07:05 PM   #3
trd_brad
trd_brad is on a distinguished road
i agree do a flush
red 89 targa tuuuurrrrboo
bone stock.......for now
anyone ever notice that inspector gadgit drives a supra?
trd_brad is offline   Reply With Quote
Old 09-27-2011, 07:45 PM   #4
nessies2003
That seemed to work miracles! Thanks everyone.
Tags
slip, supra, transmission, turbo
Transmission rant, help! Need advice or anything, asap ochowdero MKIII Supra 117 04-11-2011 10:49 PM
86.5 auto transmission removal HELP!!! elmer MKIII Supra 13 04-06-2010 10:41 PM
86.5 auto transmission removal HELP!!! elmer MKIII FAQ 13 04-06-2010 10:41 PM
Should I try to rebuild my transmission, or leave it to experts? Busted Knuckles Non-Generation Specific Questions 1 04-15-2008 01:20 AM
