Old 09-27-2011, 02:31 AM   #1
Lorin Warner
Lorin Warner is on a distinguished road
Thumbs down Seized adjusters on 87-92 front lower control arms
I'm having the same problem now on my 91 Supra as I have had in the past with another Supra (1987) with the front lower control arms. The adjuster cam bolt seizes to the steel sleeve inside the rubber bushings located in the control arms. It makes is impossible to adjust the alignment on the car. I have tried everything (including a sledge hammer) in an attempt to loosen (unseize) the adjuster cam bolt from the bushings in the control arms. Three out of the four are seized. Any ideas short of cutting the wishbone control arm out with a sawzall and then replacing the lower control arms. It seems to me that it's a VERY poor setup for alignment purposes for the northern states where salt is used on the highways.
Lorin Warner is offline   Reply With Quote
Old 10-17-2011, 10:12 AM   #2
Lorin Warner
Default My solution to frozen control arms
I finally ended up using a sawzall to make one cut on each bolt and a 4 1/2" disc grinder to cut the head off the bolt each bolt. So each bolt had to have two cuts to get it free from the car subframe. Remember, you must avoid a torch, if you wish to utilize the original bushings (which are pressed into the control arms). Once I had the bolts completely cut off, I could then remove them from the subframe. I then was able to press out the remains of the cut-off bolts with a 20 ton press. With a 20 ton press the cut-off bolts would come out (however, not easy). A huge amount of force had to exerted on the bushings to press out the old bolts. After the old bolts were pressed out, it was easy to reassemble with replacement cam bolts. Remember to use that silver gunk (anti-seize compound) to avoid the same problem in the future. This whole cutting process would be difficult if you do not have a lift to work on.
Lengthen front lower control arms - how much? Boehm MKII Supra 0 07-27-2011 10:35 PM
lower front control arms eckinator MKIII Supra 0 04-18-2010 04:51 PM
front control arms or bushings 92 7mge auto eckinator MKIII Supra 14 04-14-2010 09:50 PM
Front Lower Control Arms _dUb_ MKIV Supra 2 08-09-2006 03:24 PM
