Old 10-15-2011, 11:28 PM   #1
pandrade
pandrade is on a distinguished road
Default Engine code 24 and 31 what do they mean?
Hey everyone i have benn driving my supra for about 2 months now after i restored it. i checked the super moniter for codes and it comes up whith code 24 and 31, im woundering if any one knows what these codes mean and if there somthing that should make me stop driving untill i fix thoes problems
Any suggestions?
pandrade is offline   Reply With Quote
Old 10-17-2011, 07:46 PM   #2
Look in the MKIII FAQ for a thread on error codes and what they mean. Basically though, those are air intake temp sensor and air flow meter sensor codes... been driving without the AFM connected?
Old 10-18-2011, 12:05 PM   #3
pandrade
i was inspecting the turbo and ran it for about two minits whithout the afm wire connected untill i realized it was off. i imidiatly pluged it in but thats it
Old 10-19-2011, 07:30 PM   #4
That would set the codes. Clear them and see if they return after a few drives.
Old 10-20-2011, 02:10 AM   #5
pandrade
ok ill give that a try, you wouldent happen to know how to reset the error codes would you?
Old 10-20-2011, 02:39 AM   #6
Again... covered in the faq about error codes (although it may not be spelled out in which case you just have to follow the link)... But since we're here, pull the EFI fuse for 10 seconds.
VAF check engine light on code number #2 1989 8secmkiii owner MKIII Supra 6 01-26-2009 08:54 AM
Engine Error Code EthanMKIII MKIII Supra 11 10-15-2008 01:13 AM
need engine code skunk MKIII Supra 1 08-26-2007 01:57 AM
engine code help!!! supraboy8809 MKIII Supra 0 09-01-2006 07:33 PM
