Old 09-30-2011, 03:58 AM   #1
Killa B
Killa B's Avatar
Killa B is on a distinguished road
Unhappy 7mge-No fire on start up?
Went to start my rebuilt 7m-ge today and motor turned over as it should but im not getting any fire from the coil i do have a constant 12 volts getting to it just not a pulsating signal. Is this just a ignition control modulator failure?
1989 na turbo supra ~ 3ARacing exhaust 2.5" pipe no resinator, sports package
Killa B is offline   Reply With Quote
Old 10-03-2011, 02:10 AM   #2
87hilux7mge
87hilux7mge's Avatar
or your cap/rotor is in poor shape. check for spark from the coil wire. if you have that when you crank, but no fire from the individual spark plugs, then your dizzy may have taken a crap. have had this happen alot on cars. check for spark (not just power) at both points (coil and plugs) then get back to us.
also, to get a pulsating signal from the coil, you need a very good multimeter, and i believe it has to be analog, not digital.
Old 10-03-2011, 11:41 PM   #3
interested!
Question no fire at plugs
Hi!
Have you remembered to refit the earth from the coil plate to the cylinder head?-- this completes the coil circuit to enable the coils to produce a spark-.. no earth--no sparks.
Old 10-09-2011, 06:39 PM   #4
Killa B
Killa B's Avatar
Talking
Originally Posted by interested! View Post
Hi!
I think this was the problem there were two wires (four wires on two eye connectors) that hook up to the bottom of the intake manifold i had one on the firewall and one on the starter i put them on the intake double checked the timing and it fired right up =) ive put about 150 miles on her and she is still running strong Wooohooo!
Roll start but no key start. Need help Mrow MKIV Supra 1 09-11-2011 06:11 PM
86.5 7MGE wont start , no spark Spitfire_Fox MKIII Supra 6 06-24-2011 03:25 PM
7mge hp increase info 907mge MKIII Supra 14 02-05-2011 03:03 AM
No fire no start...! lil help please 94GT47Widebody MKIV Supra 32 09-03-2009 03:20 PM
Engine still wont start 87 supra 7mge lilsmitty MKIII Supra 12 01-12-2006 10:53 PM
