Old 10-01-2011, 11:59 PM   #1
kurth
kurth is on a distinguished road
Default 87 NA Coolant Line Diagram
Can anyone help us with finding a coolant line diagram for a 87 NA ? I have coolant leaking out of the driver side below the intake manifold and can not find where it needs to be hooked up to ?
Thanks
kurth is offline   Reply With Quote
Old 10-02-2011, 12:17 AM   #2
907mge
907mge's Avatar
http://www.cygnusx1.net/Supra/Librar...spx?F=1603&P=1
Old 10-11-2011, 11:56 PM   #3
jgentleman
jgentleman is on a distinguished road
Default Cooant line
I received a 7MGE which was halfway through the head gasket job. I would like to know where the coolant hose labeled 16267 in this drawing connects on the top side. The other side goes to a 10mm-ish metal pipe near the starter.
jgentleman is offline   Reply With Quote
Old 10-12-2011, 09:15 PM   #4
jgentleman
Default Coolant mystery line..
This is the line I am talking about. I just need to know where it goes. 1988 Supra NA 7MGE.
Old 10-13-2011, 12:33 AM   #5
El Supracabras
El Supracabras's Avatar
Throttle body?
Old 10-13-2011, 01:41 AM   #6
Yup. To the firewall side of the TB, then out from the forward side of the TB to the ISCV and then from the ISCV to the nipple on the lower intake runner flange.
Old 10-14-2011, 10:03 PM   #7
jgentleman
Default Thank you.
Thanks, guys. It did go to the intake but that hose had been crammed on to the vacuum connection for the brake booster. Everything is cool now.
I could also use a little help with the wiring of the igniter/coil. All the wires are pulled out on the harness side...
Coolant Hose Diagram IHateHacks MKIII Supra 11 07-02-2013 03:08 AM
87 Non Turbo Vacuum Line Diagram kurth MKIII Supra 4 01-30-2011 05:54 AM
Auto Supra Coolant hose pressure and return leak to oil pan and filter area? rjSupra MKIII Supra 45 01-18-2011 12:12 AM
capped metal coolant line????? twinturbolvr MKIII Supra 4 08-06-2008 04:32 AM
