Old 10-02-2011, 05:00 AM   #1
devsdad01
devsdad01 is on a distinguished road
Default Boost Trouble
I recently replaced the head gasket on my 1990 Turbo Coupe and took it out for a test spin today. It runs and idles smooth, but when the turbo spools up towards 4 psi it feels as though it looses massive amounts of power and it pulses very rapidly almost like it is missing. I set the time so I know that couldn't be a factor. The car ran fine before the head gasket blew and was boosting a solid 8 to 10 psi. Any ideas on what I may need to check or what could possibly be causing this problem?
Any information would be greatly appreciated as I am stumped!
devsdad01 is offline   Reply With Quote
Old 10-02-2011, 05:06 PM   #2
trd_brad
trd_brad is on a distinguished road
knock sensors? are they pluged in?/broke?
afm wireing?
buddy of myn has the same problem
do a code chech should tell you
if its your knock sensors then it would cause the issue your explaining as they change the timing
hope this helps
red 89 targa tuuuurrrrboo
bone stock.......for now
anyone ever notice that inspector gadgit drives a supra?
trd_brad is offline   Reply With Quote
Old 10-03-2011, 01:34 PM   #3
El Supracabras
El Supracabras's Avatar
Missing under boost? After you've checked for codes, check your coil ground and double check intercooler piping, clamps and hoses.
Old 10-03-2011, 03:46 PM   #4
87hilux7mge
87hilux7mge's Avatar
+1. i concure doctor
Tags
7mgte, boost, loss of power, mark 3
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
boost trouble excalibrate Non-Generation Specific Questions 3 10-09-2006 05:14 AM
having trouble with my boost gauge! fastsupralife Non-Generation Specific Questions 6 09-12-2006 12:57 AM
Boost Trouble... SN8KBTE Non-Generation Specific Questions 2 12-09-2005 02:07 PM
