Old 10-06-2011, 10:57 PM   #21
El Supracabras
El Supracabras's Avatar
The excessive vibrations are probably from a poorly executed conversion. If you plan on using a professional service to build a driveshaft I would think (hope) you wouldn't have any problems. In Ranmas case, it sounds like the kid she bought the car from didn't care about or more likely didn't know what he was doing. The 2 piece is pretty stout, but ripping the rubber out of the center bearing in the middle of a good race would suck. Race cars are supposed to rattle, right?
Old 10-06-2011, 11:47 PM   #22
87hilux7mge
87hilux7mge's Avatar
agreed. +1
Old 10-07-2011, 05:44 PM   #23
carl johansson
carl johansson is on a distinguished road
Thanks, thats kind of what i thought. someone here made a good point about length leading to excessive vibrations - but a one piece in this application is not real long!
As for the vibrations in a race car, the car is loud, jumpy vibrates all over the place from all sorts of things, but you would be amazed at how in tune you are to it. You can easily pick up a loose exhaust, and ID that, you can pick up a drive shaft, and ID that as either drive shaft or tires. The biggest difficulty is sorting out if the tire just picked up some melted rubber from another tire - it will vibrate and bounce like crazy till it wears off, or if you have a real tire problem. Plus everything is hard mounted, so you feel every vibration!
carl johansson is offline   Reply With Quote
Old 10-07-2011, 05:51 PM   #24
carl johansson
Originally Posted by worm611 View Post
http://shaftmasters.com/toyota-supra...iveshaft3.html
Read some posts on forums about guys running this shaft, I purchased one, but did not install it yet, quality looks great!
anybody have any other sources they like? i gotta pull the trigger on this ASAP!
Old 10-08-2011, 04:53 PM   #25
Actually, the two piece is more to do with longevity and preventing the DS from grenading on you (and yes, it helps with vibrations but don't put it past Toyota to know how to build a balanced drive shaft... They would have if not for other factors , I'm sure, they're MUCH cheaper). You can find a LOT of information on this already online including a lot of wonderful pictures of exploded one-piece DS'd sticking out rear seats or gas tanks or taking out cars behind the vehicle it was installed in. It's the whole reason DS loops/cages are required at tracks. It's all about elasticity, centrifugal force and the outward fatigue it causes. Aluminum is the most susceptible (also the worst for vibration), steel is less susceptible and CF the least (although I believe CF may have more vibration tendency than steel).
I'll see if I can find a calculator for critical rotation speeds (this is just the speed at which the most stress is seen, it doesn't mean that if you drive at that speed one you're dead... I think on the 4.30:1 it was something low like 80MPH with a one-piece aluminum DS and stock size tires).
Bah, I don't have time today to dig for all the fun pictures Google image search used to show, they've changed the sorting priorities of something. Anyway, from what I've seen with fatigue the metal shafts will spiderweb and tear in multiple places. From too much power it usually looks more like a torn paper towel roll or crumpled. Carbon fiber looks like an expensive broom when it goes (not a lot of damage potential other than the spline and forward U-joint).
The Stock two piece has a critical rotation speed about three times that of a one piece. The two piece also serves to dampen shock through the drivetrain. You can get a lighter two piece made for little money and retrofit a more common carrier bearing OR have a one piece with a thicker center sleeve welded in essentially shortening the drive shaft into two and thus raising the ceiling a bit.
Vibration will kill seals, bearings and U-joints but the DS isn't going to just pop like a cartoon gun with a finger in it.
Of a final note a lot of drive shaft shops will tell you you need to check the DS every few thousand miles for signs of spider webbing or cracking (especially one this long)... do it; It's cheap insurance and really beats having the ass of the car try to pole vault on the highway. I've only known a couple people who've had trouble with their on-piece DSs on MKIIIs, those were aluminum. I've always run steal (on various cars) and never had a problem.
Manual to Auto, Killswitch, Drive shaft wayzhack MKIII Supra 7 10-13-2010 02:35 AM
center bering for drive shaft good or bad? carl johansson MKIII Supra 3 01-10-2010 05:31 AM
one piece drive shaft mizuboi MKIII Supra 1 09-23-2006 03:35 PM
