Old 10-07-2011, 05:42 AM   #1
icey756
icey756 is on a distinguished road
Default inconsistent boost
I have been noticing that my boost is different according to what gear im in. 1st is about 4 or 5 2nd is 5 to 6 third is 6 and 4th is 7. I have a manual boost controller under the hood. I can really think of anything that would be the problem i guess. I have an aftermarket boost gauge hooked up and i also have the stock one hooked up. Im thinking either a vacuum leak somewhere or it could be where i have the new one hooked up. Idk. I'm open for suggestions and also a picture of how u have ur aftermarket boost gauge hooked up would be superb.
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
icey756 is offline   Reply With Quote
Old 10-08-2011, 05:39 PM   #2
It's not uncommon, especially as the turbo ages and spins less freely... Also in lower gears you're often not in gear long enough for the exhaust gases of overcome the turbo's inertia.
Still, I'd go through the usual steps of testing for boost leaks (with an actual tester you'd be surprised how easy leaks are to miss), check timing and check for error codes.
Old 10-08-2011, 06:57 PM   #3
icey756
Leaks from where? Like all my vacuum lines and stuff u mean?
Tags
boost, irregular, leak, vacuum
low boost psi, wtf supradad86_5 MKIII Supra 4 02-09-2014 02:05 AM
1jzgte no boost???????????????? MAP sensor? You have one? AlexSchuSupra MKIII Supra 3 06-17-2010 08:10 PM
Wont accelerate under boost, misfires, backfires, and wont idle Andrew - turbo a MKIII Supra 1 07-24-2009 01:39 PM
issue w/ boost spikes? i think? NOTORIOUS VR Non-Generation Specific Questions 17 01-17-2007 08:35 PM
installing manual boost controller 1989?? hamburgler MKIII Supra 4 07-13-2005 12:55 PM
