Old 10-08-2011, 09:34 PM   #1
Awyman18
Awyman18 is on a distinguished road
Default Cold start up has a quick squeal?
So it was recently coldish, like 35 degrees. So i would start my supra turbo up in the morning to go to work and it would squeal a bit. Wondering why its doing that? Also, my power steering started to act funny after the 3rd cold day (its now 80 again...) and the power steering is fine.
Awyman18 is offline   Reply With Quote
Old 10-09-2011, 03:54 PM   #2
carl johansson
carl johansson is on a distinguished road
check your belts, hopefully one is slipping! other stuff would be alot more expensive to fix. To diagnose you could spray all of the belts with belt dressing - if it stops squealing - either a belt is loose, or is worn out!
since you are having some iddue with power steering - i guess thats where i would start - the belt that runs the power steering pump
Carl Johansson
carl johansson is offline   Reply With Quote
Old 10-09-2011, 04:04 PM   #3
Awyman18
yea thats wat i was thinking of doing. and all the belts are brand new..like 2000 miles new.
Old 10-13-2011, 05:13 PM   #4
916MKIIIx2
916MKIIIx2 is on a distinguished road
Might be a belt installed improperly if they are all new. Make sure they aren't on inside out!
916MKIIIx2 is offline   Reply With Quote
Old 10-14-2011, 03:01 AM   #5
New belts can loosen up a little bit as they break in. Checking the tension isn't a bad suggestion.
Old 10-14-2011, 12:38 PM   #6
Awyman18
yea i was kinda thinking that cre. but i installed the belts like...6 months ago and its just now doing this lol so its not that.
Old 10-14-2011, 09:47 PM   #7
Sonyps307
Might be the clutch fan. I put a new one on my car and some times it squeals for a second then stops.
Old 10-15-2011, 04:31 AM   #8
Put a few drops of dish soap on each of the belts... do it one at a time. When the squeel goes away inspect the components on that belt and that belt.
Old 10-15-2011, 02:28 PM   #9
Awyman18
will do cre, so far no squeal, but it hasnt been very cold..lol
car suddenly wont start - never ran great anyway, esp. cold, now cranks, but won't st rjSupra MKIII Supra 41 03-21-2014 05:27 PM
Cold Start System Testing (hard starting) mrnickleye MKIII Supra 12 11-13-2010 08:32 PM
Cold Start problem mkiiisupra MKIII Supra 1 02-22-2008 05:38 AM
Waterfall sound on cold start! HELP! 88 MARK3 Non-Generation Specific Questions 7 06-29-2006 03:45 PM
my car only start when cold? supfoo514 MKIII Supra 3 06-04-2006 11:22 PM
