Old 09-29-2005, 04:53 PM   #1
boostedmkIII
boostedmkIII is on a distinguished road
Smile Adjustment?
Just put my Custom made Ic pipes on two days ago with my ssqv and did not re-cir the bov. car runs great but now it back fires sometimes after the shift Any sugestions????? I did not reset the timing since the mod.
boostedmkIII is offline   Reply With Quote
Old 09-30-2005, 01:08 PM   #2
SupraMan1784
SP58GT
redo the gear timing....u might have to retard it back a couple degrees.. not sure how many, im at work right now so ill try and reply back when i get home, it should do the trick...since i assume u are running the factory timing, the backfire shouldnt have anything to do with the i/c piping or that fact that you did not recirculate the bov, cause all recirculating does is basically reusing the boost u made alrdy...
Now: Saving for an MKIV
Broken Rides:
Old 09-30-2005, 02:44 PM   #3
monkihead
SP58GT
monkihead's Avatar
hmm. mine shoots flames sometimes, but not after every shift. i have a non-recir bov(blitz) and some other minor upgrades.
monique- better off dead
Old 10-01-2005, 01:33 PM   #4
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
runnin a bit rich there huh
see if you can tighten the bov up... i assume you can on the ssq
Pics of my build.
Do a diagnostic first!
Old 10-01-2005, 03:13 PM   #5
boostedmkIII
very rich,I still have some sort of hesiation and it has been there since I had the cam pos sensor out of the car, I took the car to toyota and they said every thing was ok and timing was ok then I sent the car to some one local they said was ok and everything checked out but it still heisatates ......Could my o2 sensor be bad and my computer not know????????
Old 10-01-2005, 09:31 PM   #6
a_zepeda926
a_zepeda926 is on a distinguished road
i dotn think it would be the o2 sensors cause i dont run any in my car and i dont have that problem
a_zepeda926 is offline   Reply With Quote
Valve Clearance adjustment gorillaguy8 MKIII Supra 5 09-03-2009 09:17 PM
Idle adjustment for A/C? Staceman MKIII Supra 4 05-19-2007 03:06 AM
"mechanical" throttle adjustment? scruffboy Non-Generation Specific Questions 0 01-04-2007 05:27 PM
idle adjustment? tonster MKII Supra 2 09-24-2005 10:09 PM
timing adjustment supra887mgte MKIII Supra 6 08-25-2005 09:40 PM
