#1 |
Took my guy to the other Toyota dealer in Tulsa, OK. Jim Norton. They replaced the power steering pump and now the water temperature gauge and oil pressure gage do not work. My instrument cluster is looking more and more like a union shop. So what could this "mechanic" have done to knock out both?
![]() Any ideals guys?
1986 Mk III MA70 7MGE Targa Top 5 Speed Stock Exhaust ![]() |
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
Well, each of them has a single wire which runs in the harness that crosses over the top of the engine in front and they both only have one connector. If he had to pull the harness out of the way (can't why he'd need to) he could have accidentally pulled them loose... OR if the insulation is bad moving the harness may have just expedited a job which was already in progress and created a short in each line. Just start with checking the connection on the sensor which runs to the thermostat neck (but isn't in the thermostat housing with the others) and wiggle the wire harness a bit. These I suspect you should be able to do yourself, reaching the oil pressure sender is a pain.
http://www.toyota-supra.info/forums/49475-post2.html
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
Thread Tools | |
Display Modes | |
1989 toyota supra non turbo low oil pressure | bayrat | MKIII Supra | 6 | 09-19-2010 05:33 PM |
high pressure in cooling system | jarekt | Non-Generation Specific Questions | 3 | 09-01-2007 06:39 PM |
Oil pressure trouble | targaiii | MKIII Supra | 5 | 08-15-2007 09:02 PM |
Low oil pressure | SupraDupra | MKIII Supra | 3 | 11-27-2006 03:21 AM |
oil pressure | johnkarl | MKIII Supra | 2 | 11-05-2006 02:11 PM |
