#21 |
Yeah im sorry my phone auto filled that.... yeah i cleared it and still occurs. O boy this is gonna be tough to fix
#22 |
![]() Toyota Racing Development Join Date: Apr 2007
Relays are easy to test and grounds are easy to clean.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#23 |
also i dont know if this is normal or will help identify whats wrong but the check engine light will not turn on unless i put it in a gear higher than one, so if i cruise 1st gear it wont turn on until i switch til second
#24 |
But no new codes are stored? Then start with the usual suspects... Battery cables, alternator (unlikely), relays and grounds.
The only other thing to try is put the diagnostic jumper in and (with a passenger to count any flashes) go for a short drive.... Should only see a code 51. There are some codes which only appear while the fault is actually happening.
Clutch kit for a 1993 JDM Toyota Supra | SpRuCe | Non-Generation Specific Questions | 0 | 04-13-2009 10:20 PM |
HElp with sports clutch!! | whitequasimodo | MKIII Supra | 3 | 05-07-2008 11:06 PM |
