Old 11-21-2011, 04:00 AM   #1
Jay633
Jay633 is on a distinguished road
Default Please help with my clutch
Okay so all of a sudden I start my car this morning and the clutch pedal is all loose... I pushed it down and it goes down like nothing. It wont cone back up wither so it wont let me put it in gear because it's fully depresses... the clutch fluid is fine, so I don't know what else it can be its a 88long supra 5 speed
Jay633 is offline   Reply With Quote
Old 11-21-2011, 01:56 PM   #2
Awyman18
check ur clutch master cylinder for a leak or air bubbles
Old 11-21-2011, 04:09 PM   #3
87hilux7mge
87hilux7mge's Avatar
yep, master cyl or slave. im thinking slave if the fluid is still topped up.
Old 11-21-2011, 10:23 PM   #4
Busted Knuckles
Busted Knuckles's Avatar
Jay, the clutch pedal will sit on the floor anytime it gets no pressure build-up. I've noticed this in many makes and models. You'll need to reach down and pull it back up.
If the system is sound, and it was just expelling an air bubble, the pedal should now be firm.
If there is still no pressure, try bleeding the clutch system. If that doesn't work, you probably have a bad master cylinder that cannot transfer pressure to the slave cylinder. This is based on your mention of plenty of fluid and no obvious leaks.
Old 11-22-2011, 04:57 AM   #5
87hilux7mge
at the same time, ive had the slaves fill up the weather protection boot with fluid, and not leak. visually i couldnt tell anything was wrong, but had no pedal and still had enough fluid in the res. this happened on my 93 nissan altima.
Old 11-22-2011, 05:07 AM   #6
The fluid level may also appear fine if you check it while the master cylinder is still pressed in. Prop the clutch pedal up and then check the fluid level. While you're on the floor check if the floor or the firewall (coming down from the cylinder) feel wet or oily.
Old 11-22-2011, 07:13 AM   #7
87hilux7mge
agreed, +1
Old 11-23-2011, 03:07 AM   #8
Jay633
Thanks so much guys well it ended it up being a faulty slave cylinder I believe but the master was already old too so I replaced both now its good to go......... on a side note I have a question. Will my supra be able to pass smog with custom three inch exhaust if I put the cats back on?
Clutch kit for a 1993 JDM Toyota Supra SpRuCe Non-Generation Specific Questions 0 04-13-2009 10:20 PM
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
