Old 11-10-2011, 11:01 PM   #1
suprra_boy
suprra_boy is on a distinguished road
Default 7m head gasket
i need a head gasket for 7m im getting a metal with arp studs first of all is there a certain brand someone would recommend and i heard of when putting the gasket on you could shave some of the head off instead of the block and that it would be cheaper and stronger is this true?
suprra_boy is offline   Reply With Quote
Old 11-11-2011, 01:42 PM   #2
Awyman18
Awyman18 is on a distinguished road
yes, get the head machined...and have them chemical bathe it. But, if u go metal, u will probably need the block machined also. Metal hg requires a very smooth surface. like...brand new type smooth. I ended up going with a ishino composite headgasket and arp studs instead of bolts. studs are alot stronger then bolts, and i didnt get the block machined so yea. how much hp are u planning on running?
Awyman18 is offline   Reply With Quote
Old 11-12-2011, 12:39 PM   #3
Sonyps307
The stock oem HG and arp head studs hold up pretty good.
Old 11-12-2011, 02:28 PM   #4
Awyman18
Yes they do but u can't reuse any of these lol but....arp head studs are so much better then arp bolts. There overkill which is nice to kno
Old 11-12-2011, 03:34 PM   #5
Sonyps307
I was talking about a new one from Toyota or driftmotion.
Old 11-12-2011, 04:03 PM   #6
Awyman18
Ishino was the supplier for toyota then, so same hg, but it will be a lot cheaper then one from toyota
Old 11-13-2011, 01:09 AM   #7
The 7M's head bolts are not TTY. They are reusable (but the age of them is why I recommend replacing them). The fasteners were never the problem.
Pro tip: Toyota's service manuals do specify which fasteners are single use and which are one use only. In the MKIII TSRM it's just an asterisk by the fastener in the exploded diagram with a note at the bottom. A few are noted in the text too.
Old 11-20-2011, 07:14 PM   #8
suprra_boy
i plan on using a metal head gasket and the arp studs what size gasket should i use
Old 11-20-2011, 07:16 PM   #9
Awyman18
depends on how much the machine shop shaves off....most is usually around 1.2mm
Old 11-20-2011, 07:20 PM   #10
suprra_boy
i really just want to get it running stock but very reliable
Re-torque head gasket from 56 ft./lb. to 75 ft./lb. (Good idea or bad idea) Randy0223 MKIII Supra 4 04-23-2011 09:50 PM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
