i noticed on my 87 turbo that under the plastic cap the little screw on top of the fuel regulator was just laying on top. im guessing someone took it out to try and thought it would increase fuel pressure or something ? car seems to runs fine, do i tighten it down a certain amount of turns or just leave it out ?
I'm assuming you're referring to the fuel pressure damper, not the regulator.... It's back by the firewall? No do not adjust it. It is essentially a very touchy secondary fuel pressure regulator and they're about impossible to reset once screwed with (get it?!
550cc injector with stock fuel pressure regulator and MAF??? | ahruizguerra | MKIII Supra | 2 | 05-13-2011 06:29 PM |
No Fuel Pressure | Wong Wei | MKIII Supra | 6 | 05-16-2010 03:03 AM |
1jz-gte Fuel pressure | AlexSchuSupra | MKIII Supra | 0 | 04-20-2010 08:07 PM |
Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
Boost and Stock Fuel | collink | MKIII Supra | 5 | 03-26-2008 11:43 PM |
