Old 09-28-2005, 10:58 PM   #1
WiseAssJester
WiseAssJester is on a distinguished road
Default Auto to manual?
Yar mateys..
I just did a search but found no info.
I'm wondering how hard it traditionally is to convert to a manual, from an automatic.
I've done it on a second generation Camaro, and it was pretty simple.. but a MK3 Supra has a lot more electrical.
Thanks in advance.
WiseAssJester is offline   Reply With Quote
Old 09-29-2005, 01:40 PM   #2
rnoswal
rnoswal's Avatar
Very easy. Just get a complete manual trans, flywheel, clutch throw out bearing and fork and the pilot bearing. I am doing the same thing to my car right now. Oh yeah you need to get the clutch pedal, master and slave cylinder and tubing. The car already has the mounting holes for everything. I am changing out my brake pedal too. It is a wider pedal with the automatic and I don't know if there is a clearance problem, but I think there is. The trans mounts are the same and the drive shaft is the same. The only thing I am not sure of is the rear gear. I have to look at the code still to see if the auto is lower numerically than the standard. If it is, it doesn't look to hard to swap out, but you might need to check into that part too.
I think thats all.
Russ
Old 09-29-2005, 02:06 PM   #3
WiseAssJester
Sweet. Just like the Camaro, then.
I don't wanna get into wiring and whut not.
Thanks.
Old 09-29-2005, 03:08 PM   #4
rnoswal
rnoswal's Avatar
I just checked the plate on both of my cars and the rear gear codes are the same. Mine are G385 with means and 3.417 ratio and 4 pinion gears and limited slip! Cool
Russ
Old 09-29-2005, 04:54 PM   #5
87supraguy
87supraguy is on a distinguished road
wouldnt you also need a new ecu to let the engine know that it is now a manual transmision and not the automtic one still hooked up?
87supraguy is offline   Reply With Quote
Old 09-30-2005, 05:19 AM   #6
WiseAssJester
What would the ECU do differently?
Old 09-30-2005, 01:17 PM   #7
SupraMan1784
SP58GT
i dont think it matters, the manual supra and the auto supra run teh same fuel map and the redlines are pretty much teh same, though the auto redline is a couple hundred rpms lower than the manual...its the same ecu...all the functions are the same so there is no real need to replace it....though u can, it wont make much difference since its the same motor...
Now: Saving for an MKIV
Broken Rides:
Old 10-01-2005, 07:53 AM   #8
rnoswal
rnoswal's Avatar
A few more things. I am at the point where I notice that I need the manual trans mount too. Also the shift boot is a little different. It appears that the upper two bolts for the manual shift boot fit the previous holes but the lower ones don't. You have to drill two new holes for them. Also the hole where the shifter comes through in the tunnel is a little smaller for the auto than the manual trans. You may need to trim the hole a little more to the rear, about an inch should do. So far though everything else seems to fit fine. Oh yeah I haven't hooked the speedo cable up yet, it is on the same side but may need the manual estension under the car, but it is late and I didn't get that far yet.
Replace the front and rear seals on the manual while you are at it. They are probably hard and starting to leak by now. Let me know how it goes.
Russ
Old 10-02-2005, 11:57 PM   #9
RNEMESiS42
RNEMESiS42's Avatar
RNEMESiS42 is on a distinguished road
How much does this all cost? I've been thinking lately that my 87 Supra would be a lot more fun if it was a stick..
RNEMESiS42 is offline   Reply With Quote
What is involved (all parts, labor, price) in auto to manual swap??? the t3d MKIII Supra 1 01-18-2007 03:01 AM
Auto to Manual Conversion justin1642 MKIII Supra 9 09-18-2006 04:22 AM
Difficulty of changing tranny from auto to manual vas85 MKIII Supra 2 06-03-2006 08:30 AM
Auto vs. manual trans. rnoswal MKIII Supra 9 12-14-2005 01:54 PM
