#1 |
Just like 300-400hp is about all I'm looking for
#2 |
![]() Toyota Racing Development Join Date: Apr 2007
http://www.summitracing.com/search/B.../?autoview=SKU
I'd go 8" x 11" or larger. Check that your PS cooler isn't going to be in the way of where you want to mount the oil cooler. If it is you can replace the pipe loop with a more efficient rail cooler and mount that wherever you like.... it doesn't nee tons of air so even the small opening beside the nose bridge of the 89+ bumper will do.
If something breaks or you need to contact a member of the administration please post HERE. Unless it's a private or administration matter please post it on the forum. It benefits no one else if car related questions aren't posted for future users and takes away from the time I'm able to spend helping on the rest of the forum. If you're so inclined I'm always more than happy to accept tips via PayPal. ![]() Tip Jar ---> ![]() |
#3 |
I did know it had a power steering cooler. I was think of mounting it beside or above the intercooler.
#4 |
You did know, or you didn't know? There are a few different ones which were used and a couple are more obtrusive than others. I believe the one from 91'+ models was the easiest as it was mounted pretty much over the bumper the whole way; This is how I mounted my aftermarket PS cooler, but I mounted mine to the support bar and ran hose to it from the hard pipe which I cut off after it came out under the headlight. '89+ GTEs may have had a similar setup but I believe there were subtle differences (which I can no longer recall).
At any rate. Installing the cooler next to the IC is fine if you don't plan on upgrading your IC. I mounted mine in front of the A/C condenser on the passenger side where the assisting fan is located between the condenser and the radiator... So it may take advantage of the extra pull on hot days. There's less room in there to fit stuff that we usually think so think it out for a while and maybe find a local vendor so you can hold it in place to see if any of the mounting locations you're thinking of will work.
| Thread | Thread Starter | Forum | Replies | Last Post |
| Na-t oil cooler question? | Sonyps307 | MKIII Supra | 3 | 11-06-2011 07:40 AM |
| oil cooler questions??? | JohnFurness | MKIII Supra | 2 | 03-31-2011 12:25 AM |
| Egr Cooler, Coolent Banjo | slader99 | MKIII Supra | 6 | 05-02-2008 06:20 PM |
| oil cooler | supraman121 | MKIII Supra | 10 | 08-27-2007 09:23 PM |
