Old 12-14-2011, 12:49 AM   #1
Awyman18
Awyman18 is on a distinguished road
Default Stock top radiator hose diameter
So I'm installing a water temp gauge and I have to buy an adaptor but I need to know what the diameter of the top hose is? Any know the total specs?
Awyman18 is offline   Reply With Quote
Old 12-14-2011, 04:29 PM   #2
Sonyps307
Im doing the same thing and also need to know the size of the hose.
Old 12-14-2011, 10:04 PM   #3
87hilux7mge
87hilux7mge's Avatar
i believe its 1.25". or just under that.
Old 12-14-2011, 11:02 PM   #4
Awyman18
well that works for me lol i mean a little bit of a stretched hose wont hurt anything
Old 12-15-2011, 06:01 AM   #5
87hilux7mge
just be careful, if the hose is slightly smaller, you can cut the hose while putting it on which will compromise its integrity. also, after heat cycling, if the hose is too small for the neck, it will crack easily and could lead to a premature failure.
neway, just be careful. good luck with it.
Old 12-15-2011, 06:55 AM   #6
What's so hard about sliding a caliper over the neck as it leaves the end tank?
Old 12-15-2011, 09:24 PM   #7
87hilux7mge
a caliper?
Old 12-16-2011, 12:34 AM   #8
That's a joke, right?
A caliper:
http://www.harborfreight.com/6-inch-...FWgaQgodRFfcrQ
Old 12-16-2011, 08:58 AM   #9
87hilux7mge
and its official, 7 days and 5 hours of sleep is starting to take its toll. no, wasnt a joke, i wasnt recognizing the context. yes, that would be a grand way to determine the outer diameter....
then again, if they had a set or could get their hands on a set, then i dont think they would be posting the question here.
Old 12-17-2011, 05:39 AM   #10
I hear ya on the sleep thing... I'm sick as a 1000HP Supra right now and despite needing sleep desperately all of my symptoms have prevented it for days... That and I'm also an insomniac.
You can get a plastic one at Harbor Freight or many hardware stores for a buck or two... So I'm going to assume that they A) didn't think on it B) aren't able to get to the car or C) are just being lazy.
Getting more for the MKIII- stock Grandavi MKIII Supra 10 10-25-2010 08:30 PM
Boost and Stock Fuel collink MKIII Supra 5 03-26-2008 11:43 PM
