-   -   Radio codes for factory radio (http://www.toyota-supra.info/forums/mkiii-supra/20112-radio-codes-for-factory-radio.html)
hall1989 01-14-2012 11:19 AM
Does anyone know how to unlock the codes on the factory radio?
cre 01-14-2012 08:33 PM
Contact a dealer... I can't recall if they can even still generate the codes though.
hall1989 01-15-2012 12:59 AM
Ok. Will do thanks!
Slistack 03-08-2015 07:53 PM
Official unlock code instructions
Toyota supra 1992 radio unlock
Master unlock code for your radio is "108431"
Turn the key on, hit buttons 1,4 and 6 at the same time,
hold them all 3 down, then hit the power button. The radio
will come up. Then hit the tune up or "> and preset 1
button,then you will get --- on the screen, using prest
one, enter the number 1, preset 2, enter 0, preset 3 enter
8. Should read 108, Now hit the tune down or < button, then
while holding it down,hit preset 1 and you will get another
--- Enter 4, 3 and 1. (431) When its all done, push the
scan button and hold it. The radio will now work and no
longer has a code in it. Hint, enter a new code, but use
the last 3 digits of the VIN, then you wotn have to worry
about remembering it.
You dont have to enter any code. It just wont be an anti
theft.
