Old 01-09-2012, 04:50 AM   #1
mikeg1988
mikeg1988 is on a distinguished road
Default 1988 7mgte gear oil location
hi everyone, im new to this forum and i recently just got a supra, gears are really stiff and i think my gear oil is low. if anyone could describe the specif location and what to do thatd be great, thanks.
mikeg1988 is offline   Reply With Quote
Old 01-14-2012, 10:28 PM   #2
Posted in the wrong section. If you're unsure please check the stickies and forum description before starting new threads there. You want the MKIII discussion forum. Thread moved.
Your new best friend: http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
Old 01-15-2012, 12:08 AM   #3
trd_brad
trd_brad is on a distinguished road
theres a plug on the drivers side of the tranny near the top i believe a 24mm wrench? put your gear oil in there
red 89 targa tuuuurrrrboo
bone stock.......for now
anyone ever notice that inspector gadgit drives a supra?
trd_brad is offline   Reply With Quote
Old 01-15-2012, 06:12 PM   #4
a400tool
a400tool's Avatar
a400tool is on a distinguished road
Suggest you drain all the old fluid and replace with new! Don't add new to the old contaminated fluid.
a400tool is offline   Reply With Quote
Old 01-15-2012, 08:16 PM   #5
You can't just add to it anyway, you'll end up with gear oil pouring out of both ends of the transmission.... BAD.
The drain plug is on the bottom and the fill plug is on the side just below the level of the BOTTOM of the drive shaft's input shaft. The fill plug it located at the "full" level so you cannot over fill the transmission. Whether you use this to fill it or decide to add from above via the shifter housing opening the fill plug so excess will drain will get you to the right amount.
quick question blacksheep Non-Generation Specific Questions 10 01-01-2007 08:19 PM
I'M AN IDIOT! Help... (1988 7mGTE). rickw MKIII Supra 8 10-21-2006 04:07 PM
