Old 01-18-2012, 06:56 PM   #1
Blindedlegacy
Blindedlegacy is on a distinguished road
Default Random stalling
This problem is getting annoying. 1986.5 na 5speed. When I am driving and I decide to reign on the heat I lose speed and can't acclerate for about 3 seconds. Also if I am at a complete stop out of no where she cuts off and I don't even notice it. and I notice it only happens on warm days, both issues. If anyone had dealt with this before please help
Blindedlegacy is offline   Reply With Quote
Old 01-18-2012, 08:52 PM   #2
Have you checked for diagnostic error codes? Look in the FAQ section for a how-to if you need. Start with that.
I don't understand what you mean by "reign on the heat"... you just referring to running the engine hard or is your climate control or engine temp part of the issue?
Old 01-18-2012, 09:20 PM   #3
Blindedlegacy
I meant to say turn on the heat. And there are no trouble codes
Old 01-18-2012, 11:41 PM   #4
No stored codes or just no check engine light? Sorry have to ask, a lot of people think that the CEL comes on if ANY codes are stored and that's not true, MOST don't cause it to light up.
The bogging when the heat comes on is something I'm going to have to think about.... The first thing that comes to mind is that the heater is drawing more current than the alternator can provide... could also account for stalling. Check the voltage from the alternator and then while watching the meter have someone turn on the heat.
As for the stalling I'd start with checking that the ISCV (Idle Speed Control Valve) isn't clogged and test it; Then test the AFM; Test and calibrate the TPS; Check for vacuum leaks or openings in the intake piping.
Old 02-02-2012, 01:32 AM   #5
Blindedlegacy
ok im sorry this took so long but i just got the codes.
22 Engine Coolant Temperature Sensor signal.
24 Intake Air Temperature Sensor signal.
41 Throttle Position Sensor signal.
if i am right 22 is that makes the car hard to start if not plugged in and its not doing that and it is plugged in
24 i have no clue where that is
41 is also plugged in and working
are these stored codes or what? also im going to try the tps calibrating
Old 02-02-2012, 01:51 AM   #6
Code 41 isn't a calibration error. Either the TPS has been unplugged at some point, is damaged or the wiring harness or ECU is damaged.
Code 22 doesn't always result in difficulty starting... It may result in difficulty starting difficulty starting in significantly cold or hot weather. Essentially though it causes the ECU to run as if it were cold: see Lots of extra fuel, base timing map, open loop operation.
Code 24, like code 41, is set if the AFM is disconnected while the ECU is powered up or if it is damaged or the wiring or ECU are damaged. I believe that if the error is persistent the ECU assumes an ambient air temp of around 70?F; If the actual air temp is significantly different this will also severely affect performance.
While these codes will all remain stored in the ECU they should not affect performance if the problem has been corrected. You may clear them and see if they return after a drive or two.
Do note that the ECU temp sensor is not the same one used for the dash gauge; So don't go thinking that because the gauge works the sensor is fine.
Old 02-02-2012, 02:24 AM   #7
Blindedlegacy
i clear the codes by disconnecting the battery right and my gauge is messed up anyways going to get a new one. do you know what the air temp sensor is?
Old 02-02-2012, 03:50 AM   #8
You only need to pull the EFI fuse for about 10 seconds. I think a minute is the recommendation. The intake air temp sensor is integrated into the AFM. Look in the EFI section of the TSRM for diagnostic info.
Old 02-07-2012, 05:17 PM   #9
Blindedlegacy
ok i just reset the codes and calibrated the tps. i put my distributor back as close to the last known right spot. (going to buy a timing light soon) im going to test it when i go to work today and hopefully the random stalling goes away. if not i am going to take it to autozone for a starting and charging test
Old 03-25-2012, 06:55 PM   #10
Blindedlegacy
Went back to this old thread because i have a question. opened up the distributor and did a brief look around and notice that i can turn the rotor a bit. i am pretty sure im not suppose to do that also i was reading somewhere that i might have gotten moisture in there and i can use wd 40 to get it out. true or false?
Tags
mk3, stalling, supra
Supra stalling Kinya MKIII Supra 2 01-06-2013 02:54 AM
random pics of random things... dannydavi Off Topic Forum 3 06-11-2007 07:13 AM
Random Overheating? MRice Non-Generation Specific Questions 10 03-24-2007 05:22 PM
Stalling Supra djairam MKIII Supra 11 11-22-2006 05:19 PM
Random stalling of the engine?? XtreeX MKIII Supra 20 11-15-2006 06:14 PM
