Old 03-30-2012, 07:18 PM   #21
Blindedlegacy
Blindedlegacy is on a distinguished road
Originally Posted by btwilson86 View Post
Before replacing the parts, do the test suggested earlier in this thread and check the voltage at the alternator and at the battery (with the car running). If the voltage at the alternator is higher than the battery, you likely have a bad connection somewhere in the charging system wiring. The voltage should be the same at both the battery and alternator, and you should have about 13.5 volts. If it's significantly lower, your alternator is likely bad and should be able to be tested at a parts store for free. Be sure to test it both with nothing extra turned on (lights, heater, etc) and with everything turned on and make sure it still produces that 13.5 volts.
Ive done that with car not running then running. Loads on and off. The readings get lower and lower from cold to operating temp. I havent tested around when it starts to shut down which is about 15 to 20 mins. But when I go to work and park my car I turn on a load such as my efans or blower motor and everything shuts down
Blindedlegacy is offline   Reply With Quote
Old 04-02-2012, 05:18 PM   #22
Blindedlegacy
Update.,new bat alt and belts and it still dies with an electrical load after hitting operation temp
Old 04-02-2012, 05:37 PM   #23
Blindedlegacy
I was talking to one of the techs at my job. Told him the story about my car from the begininh. Jumped my bros car the around the time I got my supra. That same day my coolant temp gauge stopped working. 2 techs heard that and gasped and said I might have fried my computer
Old 04-02-2012, 11:27 PM   #24
Unlikely... EFI relay or fusible link are more likely and should be inspected.
"Techs" from where?
Old 04-02-2012, 11:36 PM   #25
Blindedlegacy
"Techs" from where?
Cavalier ford. And you know which pin outs are for the ground circuits so I can at least I can do the voltage drop test
Old 04-03-2012, 01:46 AM   #26
Those dealership auto techs are always such drama queens... Unless... I hope you're not just talking about the lot techs.
http://www.cygnusx1.net/Supra/Library/TEWD/MK3/
Old 04-03-2012, 02:19 AM   #27
Blindedlegacy
It was 2 of em. But it would make sense. I found a guy with the exact same issues as me on a different forum and I msged him and now waiting for a response. That is the 1990 so I didn't think it would apply to me but u notice that the ground wires are white and black so is it the same for the ecu
Old 04-03-2012, 05:26 AM   #28
There are very few differences between pre89 and 89+ GE electrical systems... unlike the GTE. You may go by that online manual and if you get hung up due to a discrepancy just ask.
I suspect either a bad EFI relay or a bad AFM. Try testing them both after heating them up with a hairdryer. Another possibility would be a problem with the fuel pump relay and resistor pack. You can bypass both at the harness to test if this is the case.
Old 04-03-2012, 11:47 AM   #29
Blindedlegacy
I tested the air flow meter based on the haynes manual a while back and it passed. And would a relay cause the whole electrical system to do this?
And this guy had the same problem as me. http://www.supraforums.com/forum/sho...0-Voltage-drop
Old 04-03-2012, 07:10 PM   #30
Haynes/Chilton suck. I've got a ton of factory service manuals from a dozen different auto manufacturers and I've yet to come across one which is as poorly written as those two companies' offerings.
I posted a better means of testing the VAFM than what is specified in the Haynes/Chilton and TSRM just the other day: http://www.toyota-supra.info/forums/101981-post10.html You still need to test the FC switch (VERY important to pay attention to as it's a complete cutout switch) and the temp sensor as prescribed in the TSRM. The FC switch or its wiring is another possibility.
The load specific behavior of the failure isn't decidedly characteristic of a faulty EFI Relay or Circuit Opening Relay but they're simple enough to test and their failure may cause intermittent cut offs.
I don't recall you mentioning having tested them yet, but test the 100A fusible link (the old wire type used in earlier models will eventually corrode to the point of becoming a crippling restriction in the electrical system) and test the relay and resistor pack for the fuel pump.
Tags
mk3, stalling, supra
Supra stalling Kinya MKIII Supra 2 01-06-2013 02:54 AM
random pics of random things... dannydavi Off Topic Forum 3 06-11-2007 07:13 AM
Random Overheating? MRice Non-Generation Specific Questions 10 03-24-2007 05:22 PM
Stalling Supra djairam MKIII Supra 11 11-22-2006 05:19 PM
Random stalling of the engine?? XtreeX MKIII Supra 20 11-15-2006 06:14 PM
