Old 01-19-2012, 03:42 AM   #1
Jay633
Jay633 is on a distinguished road
Default Throttle Position Sensor
okay i cleared by code 11 and now i have code 51 which is the TPS. i jumped IDL and E2 in the connector and code 51 went away so im guessing replacing the sensor will do. should i just buy a new sensor (looks like its the original sensor, car has over 190xxx miles). or adjust the old one?
Jay633 is offline   Reply With Quote
Old 01-19-2012, 04:24 AM   #2
The TPS is a wear component. It consists of the IDL switch and a potentiometer. Throttle response with a new one would most likely be better than you'll see with a used one. It is however just a trim sensor, it's not going to cause significant problems if you do go with a used one.
Have you actually taken off the TPS and tested the switch when the TPS is certain to be at full stop?
Old 01-19-2012, 05:16 AM   #3
Jay633
how do i test the switch with it removed? I thought it could just be broken, and a new one would fix my code 51 problem. nut if checking it can save me cash that will be my route
Old 01-19-2012, 05:34 AM   #4
Remove it and test for conductivity across E2 and IDL. See the TSRM for more info.
Throttle Position Sensor Dan Swanson MKIII Supra 0 08-22-2009 01:58 PM
Cam Position Sensor JMoses MKIII Supra 4 08-19-2009 05:09 PM
Cam position sensor and Knock sensor Burn N' Up MKIII Supra 1 11-23-2005 11:27 PM
throttle position sensor 88turbo1 MKIII Supra 6 09-24-2005 04:51 PM
SUB THROTTLE POSITION SENSOR BYPASS TRICIA93TT MKIV Supra 0 08-26-2005 03:31 AM
