Old 02-05-2012, 05:12 AM   #1
icey756
icey756 is on a distinguished road
Default Engine pulling help needed
Ok so me and a friend are trying to get my 7mgte out of my 88 supra and we just can seem to do it. I know this subject has been beat to death but nothing seems to be working. I read that we should remove the clutch fork but i honestly dont understand how that would help in any way. Pulling the trans with the motor is not an option. please help.
1988 7M-GTE Manual Turbo, Godspeed IC, Stock HG Torque to 90FP W/ Arp bolts, Silicon water hose kit, silicon vacuum hoses, Godspeed radiator, 2 12" electric fans.
icey756 is offline   Reply With Quote
Old 02-05-2012, 04:14 PM   #2
how is pulling pulling trans. and engine not an option?? its a major pain in the ass to pull the motor on its own, especially those two trans bolts behind the head.
all you need to do to take your trans with you is, remove shifter, remove drive shaft, unbolt trans mount, disconnect tach cable and possible sensor...
as for taking the engine on its own, im not sure what your asking?? disconnect everything... and pull it out... if its not coming out, you havnt done everything yet...
Old 02-05-2012, 06:20 PM   #3
icey756
Cause the picker i have is only able to lift half a ton. My resources are limited. i have to extend the arm all the way to get over the engine so thats why taking the trans with ISNT an option. Everything looks disconnected cause its about maybe 1/2 inch to an inch away from the trans. I read two or three forums that say to remove the clutch fork but i dont understand how that would even help. I tried getting the e clip off but its such a pita.
And if your talking about any of the 6 or 8 bolts that actually connect the bell housing tot he engine were easy. the ones behind the head took maybe 5 mines for the both of them
Old 02-05-2012, 06:36 PM   #4
take off your hood, makes it easier. and your engine with trans should weigh in under 500 lbs that is under a 1/4 ton...
Old 02-05-2012, 06:46 PM   #5
icey756
hoods the first thing i took off. And i already told u its not an option. i dont have a very good jack and im using on of my jack stands on my other car. Do u have any info on the clutch fork? cause if not then ur not really helping if your going to tell me over and over to just pull the trans. Im pulling the engine to grind the rust off and paint it. The trans is just going to get in the way.
Old 02-05-2012, 09:51 PM   #6
look in the tsrm.
use the search feature to find the links...
i am not certain about the 7mgte turbo trans. but on the w58 the fork is attached to the bellhousing and does not need to be removed.
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Well crap! Advice needed with shot engine finaltable MKIII Supra 10 03-13-2008 07:35 PM
change oil pump without pulling engine Jjona5 MKIII Supra 2 02-11-2007 03:29 AM
Pulling Engine and trans adamh88 MKIII Supra 3 01-15-2007 05:36 PM
