Old 02-05-2012, 05:12 AM   #1
icey756
Default Engine pulling help needed
Ok so me and a friend are trying to get my 7mgte out of my 88 supra and we just can seem to do it. I know this subject has been beat to death but nothing seems to be working. I read that we should remove the clutch fork but i honestly dont understand how that would help in any way. Pulling the trans with the motor is not an option. please help.
Old 02-05-2012, 04:14 PM   #2
how is pulling pulling trans. and engine not an option?? its a major pain in the ass to pull the motor on its own, especially those two trans bolts behind the head.
all you need to do to take your trans with you is, remove shifter, remove drive shaft, unbolt trans mount, disconnect tach cable and possible sensor...
as for taking the engine on its own, im not sure what your asking?? disconnect everything... and pull it out... if its not coming out, you havnt done everything yet...
Old 02-05-2012, 06:20 PM   #3
icey756
Cause the picker i have is only able to lift half a ton. My resources are limited. i have to extend the arm all the way to get over the engine so thats why taking the trans with ISNT an option. Everything looks disconnected cause its about maybe 1/2 inch to an inch away from the trans. I read two or three forums that say to remove the clutch fork but i dont understand how that would even help. I tried getting the e clip off but its such a pita.
And if your talking about any of the 6 or 8 bolts that actually connect the bell housing tot he engine were easy. the ones behind the head took maybe 5 mines for the both of them
Old 02-05-2012, 06:36 PM   #4
take off your hood, makes it easier. and your engine with trans should weigh in under 500 lbs that is under a 1/4 ton...
Old 02-05-2012, 06:46 PM   #5
icey756
hoods the first thing i took off. And i already told u its not an option. i dont have a very good jack and im using on of my jack stands on my other car. Do u have any info on the clutch fork? cause if not then ur not really helping if your going to tell me over and over to just pull the trans. Im pulling the engine to grind the rust off and paint it. The trans is just going to get in the way.
Old 02-05-2012, 09:51 PM   #6
look in the tsrm.
use the search feature to find the links...
i am not certain about the 7mgte turbo trans. but on the w58 the fork is attached to the bellhousing and does not need to be removed.
Old 02-05-2012, 11:01 PM   #7
I don't remember the specifics but I believe that the fork has to be removed if it's GTE but not for the GE... pull type vs push type. Last time I tried to pull just the engine I wasted more time than I could believe.... and reinstalling was even worse.
Compare and it may make some sense:
GE
http://www.cygnusx1.net/Supra/Librar...spx?F=3101&P=1
GTE
http://www.cygnusx1.net/Supra/Librar...spx?F=3101&P=2
Old 02-05-2012, 11:54 PM   #8
icey756
Damn. Cre do u remember how u managed to remove that put that was held in place by that "e" clip? The clip was easy as hell to remove once i had my head at the right angle and wasnt straining my neck so damn bad. lol. But i sprayed penetrating oil on the pin and it still wont budge. Im debating weather i should slide the engine back in a little bit to maybe relieve some pressure on the fork? idk. Im so frustrated. I would take the trans out too but im working in my dads garage and i am limited on room. if it were summer i would just work in the driveway.
Old 02-06-2012, 01:55 AM   #9
You most definitely need to move the engine back against the transmission...
This should not be as difficult as you're making it... You've gotta learn somehow but generally people suggesting you learn from their mistakes are suggesting it because, well, they've already made the same mistake.
I've worked in small garages before. Roll the car back a couple feet, pull engine and tranny in all of 30 minutes, lower engine and tranny so that tranny's resting on a tire or rolling stand, detach engine from tranny, put engine on engine stand, move hoist and tranny out of the garage, roll car back in in time for lunch.
Anyway, yes, move the engine back, pull the fork, slide the engine forward as straight as possible while the transmission is still attached; The input shaft is pretty beefy but it's always best to proceed with caution. Absolutely disconnect the driveshaft.
Old 02-06-2012, 03:03 AM   #10
icey756
why do i need to disconnect the drive shaft?
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Well crap! Advice needed with shot engine finaltable MKIII Supra 10 03-13-2008 07:35 PM
change oil pump without pulling engine Jjona5 MKIII Supra 2 02-11-2007 03:29 AM
Pulling Engine and trans adamh88 MKIII Supra 3 01-15-2007 05:36 PM
