Old 02-05-2012, 04:14 PM   #2
how is pulling pulling trans. and engine not an option?? its a major pain in the ass to pull the motor on its own, especially those two trans bolts behind the head.
all you need to do to take your trans with you is, remove shifter, remove drive shaft, unbolt trans mount, disconnect tach cable and possible sensor...
as for taking the engine on its own, im not sure what your asking?? disconnect everything... and pull it out... if its not coming out, you havnt done everything yet...
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
Well crap! Advice needed with shot engine finaltable MKIII Supra 10 03-13-2008 07:35 PM
change oil pump without pulling engine Jjona5 MKIII Supra 2 02-11-2007 03:29 AM
Pulling Engine and trans adamh88 MKIII Supra 3 01-15-2007 05:36 PM
