heres some pics of where my cps goes and of my turbo intake.
can you tell me alil more about what im missing? ![]() ![]() this is where the cps goes, correct? ..well my question is can i use the component from my 7mge and put it on the 7mgte? if not, how much will this cost? D: ---------------- ![]() ![]() this is the turbo intake, well idk what its spose to look like or what else goes to this. this is the only piece i have for the intake part. what else is there? (under the yellow foam is a gold grill, "MAF" im assuming.) --------------------- also i have the harness and ecu for the 7mgte but the wires that plug into the ecu(car side) dont fit and on the ecu theres is another connection that i dont have on the car side.. what do i do? or what is needed to do? thaNKS IN ADVANCE this is very much appreciated from any feedback.
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP.. i really want turbo ![]() |
bumpppppppppppppppppppppppppppppp! please help
I don't have time right now to post anything in depth... The CPS is there, but it's missing it's cover. They're plastic and tend to crumble with age. You should be able to order a new cover and the seal for it from Toyota without hurting the pocket book significantly.
The part under the gold thingy is indeed the KVAFM (AFM for short... no MKIII uses a MAF). I don't see any of the oil cooler components nor the intercooler components, still waiting on those? Not the best pictures to go by. Some pics of the front and thermostat housing would be helpful too. Yes, it looks like the bulk of the intake is all present.
sorry i took forever to respond..
so the cps is there? cool, ill just get the cover and seal. toyota dealer is the only way i can get that huh? even if i did get it from a junk, that isnt the best idea right? oil cooler lines? :O i didnt know the stock turbo had them. and i wouldnt even know where they go/look like i figured i had everything for the intake, but i heard htat theres an adapter for the intake so you can have a cone filter?
may i ask for what? i would be happy to take some lol
#6 |
U can get the CPS cover from driftmotion.com he has the stock one and a metal one.
#7 | ||
That's alright... The forum's not charging yet.
Getting bashful? I was just trying to be thorough and determine whether all of the sensors were present... Not a big deal and you'll know soon enough.
#8 | ||
![]() Quote:
??not at all.. i was just wondering why? figured you noticed something wrong/gone or broke on my engine. just wanted to make sure. ill snap some photos when i can if you want
#9 |
yeah i figured they have one.. ill have to research that
#10 |
Oh, I'm sure the DM crew could put together something worthwhile, but yeah, it's not the most complex of things and can be done without a premium.
http://www.toyota-supra.info/forums/...il-cooler.html I know I've posted in more detail about this in the past but I don't have the time to dig for it right now. Basic shopping list: Around 18' steel braided oil hose block adapter (mounts where the filter is) remote oil filter head thermostatic valve oil cooler (I suggest around 8" x 12" or larger) Some 1" x 1/8" aluminum stock from home depot to make mounting brackets. Everything should be 1/2" or -10AN.
7mgte swap vs 1jz swap | Supra Saiyan | MKIII Supra | 15 | 04-24-2012 02:58 AM |
87 Supra N/A to JDM 7MGTE and R154 Swap Complete | supraturbo_mk3 | MKIII Supra | 10 | 01-11-2011 06:27 PM |
benifits of 7mge to 7mgte swap | hiawathajim | MKIII Supra | 0 | 10-15-2010 10:56 PM |
all their is to know for a 7mgte swap | mkiii<3 | MKIII Supra | 0 | 10-03-2010 10:23 AM |
7mgte Swap | SilverBullet05 | MKIII Supra | 3 | 07-17-2008 12:18 AM |
