Old 02-09-2012, 05:33 PM   #1
carl johansson
carl johansson is on a distinguished road
Default Rev limiter?
OK,
I am reluctantly putting what may be an idiot into our lemons car. My primary concern is that he will blow a shift, or slam a downshift without RPM matching, and pop the motor.
This thing is bullet proof, if you keep RPM under 6000!
So how do i limit the RPM. In my other cars I have one of those MSD E Ignitions, where I just change out a chip, don't know how to address the supra!
Carl Johansson
carl johansson is offline   Reply With Quote
Old 02-09-2012, 06:32 PM   #2
The Supra's rev limiter engages at redline. So 6,500RPM if you've got a 6M crank (86.5 through part of 89) or 6,250 if you have a 7M crank. There's no way of adjusting it without affecting the entire system's clock (see: everything else will be off). You may do what you did with your other vehicle and install an add-on for ignition control, but I don't think it's worth it as redline is pretty close to your target.
mk2 speed limiter possum MKII Supra 0 05-05-2010 05:03 PM
Is this true? Fuse removal can change limiter jdbones Non-Generation Specific Questions 0 12-30-2007 10:31 AM
Rev limiter and Dyno curves carl johansson MKIII Supra 1 11-19-2007 06:21 PM
Speed limiter cut greddy defender old dude MKIII Supra 5 04-08-2007 07:48 PM
speed\cruise control limiter removal The_Black_Beast MKIII Supra 4 03-13-2006 10:20 PM
