Old 02-17-2012, 02:14 PM   #1
tosoild
tosoild is on a distinguished road
Question engine going into limp mode
hi i got and 1990 supra turbo auto . ive just put a new engine in it and have everything plugedthat i know of but when engine first fires runs a lil ruff for a couple of sec but then engine light comes on and engine runs good at idle but when i buid up revs it has like a low set rev limiter and cant be reved but all so thers no rev tacho or oil psi readings and i cant fine any thing wrong.... can so one help please ..
the car is in mint form and its upsetting me that i have never drivn it yet
the old engine died from lack of oil filter came lose on old owner
tosoild is offline   Reply With Quote
Old 02-18-2012, 02:45 AM   #2
This belongs in the MKIII section. <moved>
We'll need some more info to help. First off you should check for diagnostic codes, see the MKIII FAQ section for a thread on how to do so.
What engine do you have 7M, 1G, 1JZ? Is the car stock of is this a turbo swap? Is the engine from a different market? Ie: Is it a JDM or USDM engine, not AUDM.
A bad CPS may account for everything but the oil pressure. If it's anything like the USDM vehicles the AUDM gauge and ECU may not be compatible with the JDM oil pressure sender.
1jz limp mode? cutt MKIII Supra 1 02-04-2012 09:07 PM
Putting JDM engine in!!! :D dannydavi MKIII Supra 24 11-02-2009 06:30 AM
1jz, possible limp mode, any ideas/info clived MKIII Supra 0 07-26-2009 05:24 AM
