ive been searching for a while and can never get the answer i am looking for so someone give it to me straight.
i know that it comes with the w56, but can you put the r154 on it? i also read someone putting a g52 on it. and which one do you think is better |
W56 was only used in Toyota trucks. The 7M came paired with a W58, R154 (7M-GTE only) or an A134E; All use different bellhousings, clutches (if applicable), flywheels and driveshafts. You *should* be able to mount any transmission from the same series to a matching bellhousing but that doesn't mean that other changes won't need to be made; For example while a W56 will mount to the 7M-GE W58's bellhousing and clutch will work, the extension housing may need to be replaced and a different driveshaft fabricated.
With custom work you can fit a multitude of transmissions from various manufacturers in there; The Turbo Hydro 350 is one popular choice. Yes, you can swap in a R154, but if you're car isn't making more than 350hp at the wheels I have no idea why you would want to... The R154 is considerably heavier and doesn't shift very smoothly compared to the W58. The gearing is almost identical (the big difference in gearing between GTE and N/A is in the differential).
#3 | |
![]() Quote:
i have heard of guys running 300-400 hp with no problems as long as you dont get wheel hop.
wheel hop=w58 explosion. there is people running around 600 with the w58, but they only get a few 1/4 mile runs before she bombs. newer years of the w58 are no different than the 1982 w58 sitting in my garage, just shifter locations change over the years.
1984 supra - 1uzfe - w58 - 4.10 - 1 piece aluminum shaft. |
#5 | |
![]() Quote:
#6 |
unless your drag racing...
like i said, avoid wheel hop, and dont worry about your tranny... r154 is stronger, supposedly... ![]() ![]() ![]() just swap it if your really worried about trans strength. me i just have ammunition. ![]()
Tags |
7mge, g52, r154, transmission, w56 |
Transmission rant, help! Need advice or anything, asap | ochowdero | MKIII Supra | 117 | 04-11-2011 10:49 PM |
7mge hp increase info | 907mge | MKIII Supra | 14 | 02-05-2011 03:03 AM |
7mge R154 Manual Trans | nnate1228 | MKIII Supra | 0 | 03-28-2009 05:59 PM |
Should I try to rebuild my transmission, or leave it to experts? | Busted Knuckles | Non-Generation Specific Questions | 1 | 04-15-2008 01:20 AM |
1990 7mge Ecu, Auto Transmission | routeinet | MKIII Supra | 1 | 05-27-2007 01:03 AM |
