Old 02-20-2012, 12:45 AM   #1
phat_toaster
phat_toaster is on a distinguished road
Default Turbo gasket replacement...
So I've got an '89 Supra Turbo and just took it into the shop to have the exhaust manifold gasket replaced (it was leaking) and the shop said the turbo gasket needed to be replaced as well. What is a reasonable price for the turbo gasket kit and a good source for getting said kit? I just want to make sure I'm not getting screwed. Thanks in advance!
'89 Supra Turbo Sport Roof, White on Blue
-3" Magnaflow Exhaust
-HKS Blow Off Valve
-GReddy Turbo Timer
-Tokico Illumina II Struts
phat_toaster is offline   Reply With Quote
Old 02-20-2012, 12:59 AM   #2
http://www.ebay.ca/itm/87-92-TOYOTA-...item2c5eb9f62d
13 dollers^^^
http://www.ebay.ca/itm/Toyota-Supra-...item4162017e25
39 dollers^^^
a shop will sell them for more.
other adds show them seperate for about 13 dollers each, always check the sellers feedback before buying on ebay. you never know...
Old 02-20-2012, 01:01 AM   #3
phat_toaster
I was quoted $128 for some turbo gasket kit. That sounds rather out of line to me.
-HKS Blow Off Valve
-GReddy Turbo Timer
Old 02-20-2012, 01:06 AM   #4
rip off
a head gasket for this car is about 100dollers FROM LORDCO!!!
edit:
infact i have purchased a hefty amout of 7m and 5m cylinder head gasket kits and they usually sit between 125 and 160 dollers...
Old 02-20-2012, 06:24 AM   #5
phat_toaster
That's kind of what I was thinking, but I didn't want to call anyone's bluff before I had some solid info first. Thanks!
-HKS Blow Off Valve
-GReddy Turbo Timer
Old 02-20-2012, 07:42 AM   #6
Two different things. There is the turbo gasket which sits between the turbo and the elbow, the gasket between the elbow and down pipe, There is the manifold gasket and the gasket between header and turbo, the gasket for the cooling flange and the gasket for the oil lines.... then there's the rebuild kit for the parts INSIDE the turbo... The rebuild kits for just the turbo and the kits which include the other gaskets are not $10 to $30.
Toyota does want a good deal of money for everyone of these... If you're not getting a shop discount you're looking at an MSRP of about $70 for ONLY the gasket between turbo and elbow.
Their quote may not be out of line, but they're not shopping where you'd like for them to OR they're talking about replacing more than you think... Ask them to clarify.
head gasket gone would it give oil in turbo intake johnkarl MKIII Supra 7 10-31-2006 06:38 PM
